Support thread for: PG3 v3.1.21 (May 22, 2023)
I'm running Polisy 5.6.0 and PG3 should have been current. After completing the Upgrade Packages from the AC I did a restart on PG3. Now when I try to launch the PG3 browser interface I'm getting a "ERR_CONNECTION_REFUSED" in the browser window. I've tried doing a full reboot from the AC but it didn't help. Any ideas on what to do next?
The package is missing a file that prevents PG3 from starting.  We're working to get it updated.
  • Thanks 3
The package has been updated.  I believe all you need to do is run the "Upgrade Packages" again.
  • Thanks 1
Works for me. Also, I get 5 beeps in succession, not 4 as always stated.
1 hour ago, PeteEaston said:
Up and running, thanks for the quick work!
and i also got 5 beeps not the usual 4
The extra beep is left over from a previous special sale UDI held for beeps. Don't announce it too loudly or everybody will want it free also. You could get a bill.
  • Like 1
  • Haha 1
Ooo...  I'm Special!
  • 3 weeks later...
Posted (edited)
After IoX upgrade to 5.6.2 -- IoX seems to be working fine. PG3 seems to be working fine as far as NS interaction with IoX and devices.
However:
  1. Not able to load Production nor Non-Production NS Store.
    • Upon clicking Node Server Store, no dropdown is defaulted. Text at the top stuck at "Getting installable Node Server list from Polyglot Store. Standby....". Title says "PG3 Node Server Store ; Current Node Servers: 0"
    • Using the dropdown to select either Production or Non-Production, green progress window bottom right loads, but the text at the top stuck at "Getting installable Node Server list from Polyglot Store. Standby....".
    • Once a dropdown is selected and Refresh is clicked, empty table loads (just column headers visible) and the "Getting installable Node Server list from Polyglot Store. Standby...." text disappears.
  2. Not able to load any purchases from Purchases tab.
    • Upon clicking Purchases tab, green progress window bottom right loads, but the text at the top stuck at "Getting list of purchases from UDI Portal. Standby....".
Have rebooted IoX 2x and PG3 3x since 5.6.2 IoX upgrade.
PG3 Version 3.1.21
Status: Connected
Frontend Version: 3.1.21
IoX Version: 5.6.2   Connected
PG3 log:
6/12/2023, 19:52:50 [pg3] warn: MQTTS: keepaliveTimeout: pg3frontend_xJKC0
6/12/2023, 19:52:50 [pg3] error: MQTTS: clientError: pg3frontend_xJKC0 keep alive timeout
6/12/2023, 19:52:50 [pg3] info: MQTTS: Client Disconnected: pg3frontend_xJKC0
6/12/2023, 19:52:55 [pg3] info: MQTTS: Client Connected: pg3frontend_xJKC0
6/12/2023, 19:52:56 [pg3] info: Requesting Portal authentication from frontend UI after 1 seconds
6/12/2023, 19:53:00 [pg3] info: Refreshing node server store data
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Airscape
6/12/2023, 19:53:01 [pg3] info: Checking for changes in HusqvarnaMower
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Timedata
6/12/2023, 19:53:01 [pg3] info: Checking for changes in YoLink
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Sun
6/12/2023, 19:53:01 [pg3] info: Checking for changes in PurpleAir
6/12/2023, 19:53:01 [pg3] info: Checking for changes in UnifiProtect
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WLED
6/12/2023, 19:53:01 [pg3] info: Checking for changes in AERISWeather
6/12/2023, 19:53:01 [pg3] info: Checking for changes in RYSE-shades
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Flair
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Airthings-C
6/12/2023, 19:53:01 [pg3] info: Checking for changes in August
6/12/2023, 19:53:01 [pg3] info: Checking for changes in HarmonyHub
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Roku
6/12/2023, 19:53:01 [pg3] info: Checking for changes in MiLight
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Sensibo
6/12/2023, 19:53:01 [pg3] info: Checking for changes in AVRemote
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WeatherBit
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Virtual
6/12/2023, 19:53:01 [pg3] info: Checking for changes in NanoLeaf
6/12/2023, 19:53:01 [pg3] info: Checking for changes in NOAA
6/12/2023, 19:53:01 [pg3] info: Checking for changes in OnkyoAVR
6/12/2023, 19:53:01 [pg3] info: Checking for changes in LiFX
6/12/2023, 19:53:01 [pg3] info: Checking for changes in VirtualButtons
6/12/2023, 19:53:01 [pg3] info: Checking for changes in ST-Inventory
6/12/2023, 19:53:01 [pg3] info: Checking for changes in ATest
6/12/2023, 19:53:01 [pg3] info: Checking for changes in eWeLink
6/12/2023, 19:53:01 [pg3] info: Checking for changes in AMINEM
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Roomba
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WeatherLink
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Russound
6/12/2023, 19:53:01 [pg3] info: Checking for changes in TeslaPW
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Rachio
6/12/2023, 19:53:01 [pg3] info: Checking for changes in ST-Nuheat
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Hue
6/12/2023, 19:53:01 [pg3] info: Checking for changes in UnifiPresence
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Holidays
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Sonos
6/12/2023, 19:53:01 [pg3] info: Checking for changes in iAquaLink
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Climacell
6/12/2023, 19:53:01 [pg3] info: Checking for changes in ST-Sonos
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Notification
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WirelessTag
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Volumio
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WeatherPoly
6/12/2023, 19:53:01 [pg3] info: Checking for changes in EnvisaLink-HW
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Bond
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BalboaSPA
6/12/2023, 19:53:01 [pg3] info: Checking for changes in HolidaysGoogle
6/12/2023, 19:53:01 [pg3] info: Checking for changes in OpenSprinkler
6/12/2023, 19:53:01 [pg3] info: Checking for changes in MessanaRadiant
6/12/2023, 19:53:01 [pg3] info: Checking for changes in DavisWeather
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Twinkly
6/12/2023, 19:53:01 [pg3] info: Checking for changes in IFTTT-Webhooks
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Wemo
6/12/2023, 19:53:01 [pg3] info: Checking for changes in WeatherFlow
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Ping
6/12/2023, 19:53:01 [pg3] info: Checking for changes in eISYIR
6/12/2023, 19:53:01 [pg3] info: Checking for changes in TeslaEV
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BASIRRIGATION
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Backup
6/12/2023, 19:53:01 [pg3] info: Checking for changes in DysonPureCool
6/12/2023, 19:53:01 [pg3] info: Checking for changes in AVServer
6/12/2023, 19:53:01 [pg3] info: Checking for changes in EnvisaLink-DSC
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Govee
6/12/2023, 19:53:01 [pg3] info: Checking for changes in OpenWeatherMap
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BlueIris
6/12/2023, 19:53:01 [pg3] info: Checking for changes in MagicHome
6/12/2023, 19:53:01 [pg3] info: Checking for changes in RainMachine
6/12/2023, 19:53:01 [pg3] info: Checking for changes in MQTT
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BASPOOL
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Acurite
6/12/2023, 19:53:01 [pg3] info: Checking for changes in MyQ
6/12/2023, 19:53:01 [pg3] info: Checking for changes in VenstarCT
6/12/2023, 19:53:01 [pg3] info: Checking for changes in iTach-IR
6/12/2023, 19:53:01 [pg3] info: Checking for changes in Plex-WebHook
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BASGARAGE
6/12/2023, 19:53:01 [pg3] info: Checking for changes in FlumeWater
6/12/2023, 19:53:01 [pg3] info: Checking for changes in VUE
6/12/2023, 19:53:01 [pg3] info: Checking for changes in BASPI6U6R
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Caseta
6/12/2023, 19:53:02 [pg3] info: Checking for changes in ShellyRGBW2
6/12/2023, 19:53:02 [pg3] info: Checking for changes in ST-EcoWitt
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Blink
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Kasa
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Kaiterra
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Intesis
6/12/2023, 19:53:02 [pg3] info: Checking for changes in ELK
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Sense
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Somfy
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Ring
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Netatmo-WS
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Ecobee
6/12/2023, 19:53:02 [pg3] info: Checking for changes in BASAO
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Wake-On-Lan
6/12/2023, 19:53:02 [pg3] info: Checking for changes in LinkTap
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Push
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Camect
6/12/2023, 19:53:02 [pg3] info: Checking for changes in SolarEdge
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Meteobridge
6/12/2023, 19:53:02 [pg3] info: Checking for changes in TotalConnect
6/12/2023, 19:53:02 [pg3] info: Checking for changes in MySmartBlinds
6/12/2023, 19:53:02 [pg3] info: Checking for changes in HueEmulator
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Eagle-200
6/12/2023, 19:53:02 [pg3] info: Checking for changes in AmbientWeather
6/12/2023, 19:53:02 [pg3] info: Checking for changes in HoneywellHome
6/12/2023, 19:53:02 [pg3] info: Checking for changes in Noyito-Relay
6/12/2023, 19:53:02 [pg3] info: Checking for changes in DSDTech-Relay
6/12/2023, 19:53:03 [pg3] info: Checking for changes in DSC-IT100
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Roku
6/12/2023, 19:53:03 [pg3] info: Checking for changes in PythonTemplate
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Example-1
6/12/2023, 19:53:03 [pg3] info: Checking for changes in AVRemote
6/12/2023, 19:53:03 [pg3] info: Checking for changes in ATest
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Roomba
6/12/2023, 19:53:03 [pg3] info: Checking for changes in TestTeslaEV
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Example-2
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Notification
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Example-4
6/12/2023, 19:53:03 [pg3] info: Checking for changes in OpenSprinkler
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Example-3
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Hubitat
6/12/2023, 19:53:03 [pg3] info: Checking for changes in eISYIR
6/12/2023, 19:53:03 [pg3] info: Checking for changes in VueTest
6/12/2023, 19:53:03 [pg3] info: Checking for changes in MagicHome
6/12/2023, 19:53:03 [pg3] info: Checking for changes in solaredge_poly
6/12/2023, 19:53:03 [pg3] info: Checking for changes in iTach-IR
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Ring-Beta
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Kasa
6/12/2023, 19:53:03 [pg3] info: Checking for changes in ELK
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Ecobee
6/12/2023, 19:53:03 [pg3] info: Checking for changes in Rheem_Tankless
6/12/2023, 19:53:03 [pg3] info: Checking for changes in TeslaEV_BETA
6/12/2023, 20:00:05 [pg3] info: MQTTS: Client Connected: pg3frontend_cAQ4s
6/12/2023, 20:00:06 [pg3] info: Requesting Portal authentication from frontend UI after 1 seconds
6/12/2023, 20:00:17 [pg3] info: MQTTS: Client Disconnected: pg3frontend_cAQ4s
6/12/2023, 20:00:22 [pg3] info: Successful login by admin
6/12/2023, 20:00:22 [pg3] info: MQTTS: Client Connected: pg3frontend_41Ojr
6/12/2023, 20:00:23 [pg3] info: Requesting Portal authentication from frontend UI after 1 seconds
6/12/2023, 20:00:31 [pg3] error: Failed to get transaction report
6/12/2023, 20:00:31 [pg3] error: Error: Request failed with status code 400
6/12/2023, 20:00:31 [pg3] error: transactionReport: TypeError: Cannot read properties of undefined (reading 'data')
Edited by residualimages
Typo on what version IoX updated; additional log data
So, after *another* upgrade packages and manual reboot on IoX and another reboot on PG3, now everything seems to be populating correctly as far as NS Store and Purchases.
      38.1k
      380.4k
