IPhone Apps for Eisy
Are there any Apps that I can use to control my devices that are controlled by Eisy? I am deciding when to migrate from my ISY to eisy.
Solved by DennisC
Thanks Dennis.  I just set it up on my ISY. I noticed that my Favorites folder on my iPad does not sync with the one on my iPhone.
Also, when I tap the favorite, it does not toggle the light on or off on the iPad, but simply opens up options (see attached) even when I tap the left/right arrows.  It works fine on the iPhone.
Thoughts?
Thoughts?
Each device can have it's own Favorites. You can copy from one device to the other, as long as it is the same platform (android vs iOS), by making a backup and importing to the other devices. Instructions are in the wiki
For your second issue, you are in edit mode. Edit mode is toggled on/off by the pencil icon in upper right corner.
Spend sometime reading the instructions in the wiki, there is a lot of customizations that can be done. For example, changing colors for on/off
