Venstar Thermostat V2
jcip
I have 4 thermostats... on one of them the fan control constantly reads "ON" whether the fan is ON or OFF. I have delinked and relinked the device which solves the issue for about a week and then it happens again. Has anyone else experienced this issue?
Link to comment
  • 4 months later...
Hello jcip,
Yes, they are. I assume you have four nodes for each.
The next question is whether or not you are on 2.7.15 firmware. If not, please do so. If yes, then I recommend doing a factory reset on the thermostat, remove it from ISY, and then add it back in. If that still doesn't work, then I would have to think a problem with the thermostat.
Link to comment
i do have four nodes and i am on firmware 2.7.15. i will follow the procedure next time i experience the problem. at the moment, the fan and heat nodes are not reading a state at all (neither on or off)... does that sound correct? but the thermostats all seem to be functioning properly... they are all set to cool and the cool control is "on" or "off" as appropriate.
Link to comment
      37k
      371k
