A Dial to Change a Variable
Ross
I would like to turn a dial, then press a keypad button which would cause a variable to change based on where the dial is pointing (e.g., 1-100).
My use case is: I have 100 (and growing) Sonos playlists.  Currently, I can set a State Variable which runs a program to load/play that particular playlist.  I have rigged a couple of keypads to have lettering similar to a phone.  If I keypress S-U-R-F, the Beach Boys play.  Keypressing J-A-Z-Z changes the variable accordingly.  It works fine, but I have other ideas.  So, I was thinking of some kind of dial.
I'd appreciate your thoughts.
Ross
Insteon's new i3 dimmer comes to mind.  Cap the load wire and use it's status which should be 0-100.  The problem is there's no way to know what "level" you've adjusted it too.  I have no idea how to create a display that would update in real-time with that dial turning.
  • Like 1
@MrBill I saw the I3 which gave me this idea.  However, I didn't think about capping the load wire as I know next to nothing about electricity.  I'll get one and start tinkering.
It doesn't have to look living-room-beautiful. I could put a pointer on the dial and create a thermometer-type display behind it.   I was also thinking about an Arduino - I'm just not up to speed on how to set the variable from one.
By the way, the pic is what I'm using now to change the variable based on pressing 4 buttons (I use the clear buttons).  I just have to make sure my 4-letter codes for each playlist are all different.
Ross
Posted (edited)
My thoughts turn to an amazon echo where your combinations of selections have no limits.
I used a KPL for a combination lock to operate security functions, and reset water alarms, re-enabling a well pump, a dishwasher, and a laundry washing machine, each on it's own code sequence.
Using all those keypad buttons seems like a lot of work.  If you want wall-based vs. phone base control, perhaps just put an i-pad Mini on the wall with a Luxe port case and use the Sonos app.  Then you can repurpose those buttons for your 12 favorite playlists or something else.
Expand
@larryllix Larry, I should have given credit where it was due.  I "sampled" your program to create mine.  I tucked it away a few years ago and finally found a way to use it in my house.  So, thank you!
@EW1 Thanks for your suggestion.  I'm an Android guy myself and I don't know the Apple stuff.  And, I have issues with the Android tablets that seem to always need updating and whatnot.  Pressing 4 buttons isn't that bad and it seems like "magic" to guests.  Of course, so is Alexa - but I haven't gravitated to the spoken word yet.
Ross
