Zigbee - Device Support Requests
4 minutes ago, Michel Kohanim said:
Thanks. As you can see, it's not reporting any "energy" related clusters.
Could that be because I don't currently have any load plugged in? I'll connect something, x-ray it again, and see if the results are different. I'll post them if that's the case. Thanks!
I plugged in a LED bulb in a lamp (a Hue bulb in fact, was close by). The last line now shows:
Integer DATA devices.59391.endpoints.1.clusters.1794.data.instantaneousDemand = 71 (0x00000047)
Then added a wireless phone base station:
Integer DATA devices.59391.endpoints.1.clusters.1794.data.instantaneousDemand = 85 (0x00000055)
The other consumption fields remains the same.
Ok, restarted admin console, no change. Ran update packages again and rebooted (I had upgraded to 6.0.5 a few hours ago), then reran interview. Still looks the same. Should I be seeing something new, like a consumption field?
Ok I'll do that, once I get back home later.
Thanks for this! It will be better than the Emporia plugs, keeping it all local.
