How to Migrate from PG3 to PG3X
Go to solution Solved by tazman,
Hello... I have looked all over the place.  How do you upgrade from PG3 to PG3x?  I updated IOX to 5.6.3.  Can't locate where in the PG where to update it.  It's running on PG3 version 3.1.21
Oh man.... Too easy, now I remember seeing this.  Thank you!  Maybe you can tell me or direct me to the pros/cons of migrating to PG3x?  The only reason why I'm wanting to migrate, is to try the "Notification" feature within UDI mobile and or the GEO fencing addition.  Also when I attempt to go to the hyperlink I get a security error.  See attachment.  Thanks for replying.
I would recommend just doing it because you're going to have to eventually - I've done it on a Polisy and I don't recall it being too bad...
That's really the only reason you need, it's not going to be available on PG3.
Try again by copying link below and make sure you are local.
Enable PG3x: https://polisy.local:8443/rest/pg3x.enable
Reboot and wait for a beep + 1.
Migrating node servers from PG3 to PG3x might take up to 2 minutes per node server. So, please be patient
Once all node servers show connected, reboot again.
      37.6k
      376.3k
