question - what is Install Dev Packages
What is the difference between upgrade packages and install Dev. Packages? When should each be used? Thanks in   advance for any
answers.
Thanks, wac
Solved by DennisC
Install Dev. Packages is right next to Upgrade Packages in  configuration setting
@wacvmd personally wouldn't ever press such a button unless UDI/UDI Support said to. I think somewhere in the early days of the eisy there was some troubleshooting functions that allowed UDI to get more information from users and that button just hasn't been removed.
For the most part the only button needed for updating the Polisy or eisy is "Upgrade Packages" then "Reboot".
I think even Enable TPM and Upgrade Bios were for Polisy and not sure they even apply to eisy. But not 100% certain. I just don't make a habit of randomly pushing buttons unless specifically told to for a good reason. :)
My bad, I totally overlooked it. I believe it has been used to fix node server issues. I'm not sure exactly what gets updated.
