toddlock Posted September 1, 2023 Share Posted September 1, 2023 I am looking for recommendations for a motion sensor to detect raccoons that are tearing up my grass. I have a program to turn on the outdoor lights and sprinkler to scare them away; however, I’m having trouble getting my Zwave Ecolink Motion Sensor to work correctly. I have an eisy with the ZMatter Zwave 700 series. I would be delighted to hear if anyone has found a reliable Motion Sensor that works well. Thanks in advance for any help. Link to comment
Techman Posted September 1, 2023 Share Posted September 1, 2023 Take a look at the Aeotec Multisensor 6 Link to comment
toddlock Posted September 2, 2023 Author Share Posted September 2, 2023 Thanks, Techman, I'll look into this sensor. Link to comment
TheA2Z Posted September 2, 2023 Share Posted September 2, 2023 I assume you need a weatherproof motion detector, unless you have racoons running around the inside of your house 😉. Or you have maybe an eave where weather cant get to it. I dont think the Aeotec is an outdoor rated sensor but I may be wrong. I have motions inside the house. I have motions in my outdoor floodlights. But no standalone motions on the exterior. There isnt alot out there classified as a zwave outdoor motion. If I were to consider buying one though I would look at the Zooz Outdoor motion sensor. There may be some options on the Zigbee side to look at but you would need to ensure supported by eisy. I know Hue has one as well. Link to comment
toddlock Posted September 2, 2023 Author Share Posted September 2, 2023 TheA2Z, Thanks for the incite, Yes this would be outside, and I agree there are a few options. I did try Zooz ZSE29 and had to return it because I couldn't get it to connect to eisy. It connected at first, and then I dropped off, and no matter what I did trying to connect and disconnect it, I could never get it to work. I spent hours and finally threw in the towel and sent it back. I'll look at the Zigbee now. Link to comment
TheA2Z Posted September 2, 2023 Share Posted September 2, 2023 16 minutes ago, toddlock said: TheA2Z, Thanks for the incite, Yes this would be outside, and I agree there are a few options. I did try Zooz ZSE29 and had to return it because I couldn't get it to connect to eisy. It connected at first, and then I dropped off, and no matter what I did trying to connect and disconnect it, I could never get it to work. I spent hours and finally threw in the towel and sent it back. I'll look at the Zigbee now. @toddlock Yeah I dont think it is zwave 700 so shorter range. You could go this route, but wouldnt be connected to home automation: Motion Activated Sprinkler - Yard Enforcer – OrbitOnline: Link to comment
toddlock Posted September 2, 2023 Author Share Posted September 2, 2023 TheA2Z, I have heard of these, and this is my Plan-B if the esiy doesn't work out. Link to comment
Geddy Posted September 3, 2023 Share Posted September 3, 2023 @toddlock is there anyway you could add a Ring camera (Floodlight or Spotlight)? You could then use the Ring node server and the motion from that to trigger other device. The Ring lights can be another deterrent or you can set them not to come on and only blast the sprinklers I have a floodlight cam that triggers lights on motion in the middle of the night. So far it has worked really well. Link to comment
RPerrault Posted September 3, 2023 Share Posted September 3, 2023 elk if you have it your choice of devices that actually work Link to comment
Whitehambone Posted October 20, 2023 Share Posted October 20, 2023 @toddlock, I use motion from my IP cameras to trigger lights outside. It seems to work pretty well depending on what is in your field of view. 1 Link to comment
