ISY994 and Power Outage
gadgetfreak
A few days ago my power went out for around 2 minutes. Unfortunately I didn't have my ISY on a battery backup then (I do now). When the power was restored, all the switches went back to their previous state. But then, the ISY finished rebooting and everything turned off.
Does anyone know why that happened? I found an option "Catch up schedules at restart" which was not checked. But I am not sure that is it. Because the ISY simply turned off everything after it rebooted.
Does anyone have any other ideas? Thx.
Link to comment
I’m sorry that I can’t propose a fix for this problem but only to say that this hasn’t yet happened to me.  My house power is now backed up with solar and Tesla batteries.  We get a lot of power grid failures because our northern California public utility has spent decades pocketing cash instead of keeping their grid reliable. Most of the time, the Tesla system kicks in fast enough that ISY isn’t disturbed, but twice the switchover took enough time that ISY saw enough of a power cycle and rebooted.  After the reboot, all was running as before.
I didn’t know about this “Catch up schedules at restart” option.  If you can tell me where you found this box to check or not check, I will look to see if I have mine checked.
I have my house computer and router running off their own UPS, which existed before I added solar, and it switches much faster than the Tesla system saving those systems from rebooting.  I haven’t yet connected ISY to that UPS because of power routing complications to where ISY is located and because I’m sure that the PLM that drives the Insteon signals can’t be filtered by a UPS.  But I am going to separate out the power to ISY from the PLM power so that I can put ISY on the UPS.  I added some circuitry to an  Insteon IO Linc module to warn me when the grid is off, and the programing for that warning got overly complicated to handle grid loss with and without possible reboots.  The program will be simpler and more rational if I can eliminate ISY reboots happening with grid power loss.
Link to comment
I figured plugging the ISY into a battery backup (with the PLM directly in the wall) may solve the issue as it can keep the ISY on until the generator kicks in. But, as I am seeing, having all the lights turn off on ISY reboot should not be happening. In the forums, it asks to check if any of my programs are set to run at startup. They are NOT.
Below are my settings but I am not sure any of those make a difference.
Link to comment
I have “Wait while busy reading” and “Query at Restart” both checked.  I don’t have “Catch up schedules at restart” checked.  But also, I have all my programs that I want to be free running set to auto start at startup.  That is crucial, I believe.
Link to comment
So, since I also have programs based on time of day, and the only THEN statement in those programs is to turn ON a scene (even though some of the device commands in that scene are to go off), I guess the only other thing to do is to check all the boxes that you have checked and see what happens. Thanks.
Link to comment
Thanks elvisimprsntr for the warning about running ISY on a UPS with the PLM necessarily off.  I will avoid trying that out and deal with the complications of my power-loss program when an ISY reboot accompanies a temporary loss of power.
Link to comment
On 10/10/2023 at 10:14 AM, elvisimprsntr said:
During a momentary power outage, the ISY loses communication with the PLM and frequently locks up. I’ve always found that it is better to not put the ISY on UPS power and just let it reboot.
I don't think this is a universal occurrence.
I've run my ISY 99, ISY 994, and Polisy boxes on UPS power since 2010 while the PLM is always plugged into the house wiring with no power backup.  In the more than a decade of use, and many short or long power outages, I've never had the communications between the ISY/Polisy and PLM become locked up due to a power failure. I'm not sure what's different about our respective installations, but serial comms lockup is not an expected result of a power failure to the PLM while the ISY stays powered.
Edited by Craigb
spelling
Link to comment
In South Florida, momentary (<2 seconds) power interruptions are a common occurrence (weekly), even on clear sunny days.   Since FPL installed smart meters, brown outs are extremely rare.  When I had the ISY-99(4)i on UPS power, 90% of the time it would lock up. In fact, I actually prefer to see the lights flash off, then back on when the ISY reboots.  Let's me know all systems are go.    Choose what works best for you.
Edited by elvisimprsntr
Link to comment
