Isy to EISY transition adding ELK Module - errors
JSchumann
  On 10/18/2023 at 9:07 PM, JSchumann said:
OK, done. In admin console I go to my area then on the bottom there are drop downs.  I change disarmed to arm away and hit set armed status and it changes back to disarmed.  Still get error messages.  Am I doing it right?
Expand
1. Is the "Arm Up State" = "Ready To Arm"?
2. Is the user_code set to a valid code entered in ElkRP2?
3. Is the ElkRP2 Disconnected from your ELK?
If the answer is yes to all 3, then please download log package and PM to me again.
Expand
yes to all 3.  Sent package
  On 10/19/2023 at 2:22 AM, DennisC said:
After the reinstall, did you try arming from admin console?
Expand
After troubleshooting on Messenger, we determined that I inserted a problem by changing my time zone after installing the elk module.  This caused a 3 hour time difference in the key files.  I had to delete the elk module from admin console and uninstall elk module.  Then I reinstalled elk module and did configuration.  After all nodes were imported, I tried arming from admin console and udmobile and it worked, no TCP errors.
I am still getting the other errors, but I think they are related to EISY.  Will continue working on them.
John
      376.9k
