ISYhbsh01 Posted November 5, 2023 Posted November 5, 2023 (edited) Hi, Does this nodeserver use a local API or it goes thru the cloud? THanks. Edited November 5, 2023 by ISYhbsh01
Solution Goose66 Posted November 5, 2023 Solution Posted November 5, 2023 Currently goes through the Cloud, and in a very circuitous route at that.
Goose66 Posted November 5, 2023 Posted November 5, 2023 Also the Honewell Home plug-in (formerly node server) allows you to see the "Priority Type": "Pick a Room," "Follow Me," or "Whole House," but IoX can't change it or select a particular remote sensor.
Goose66 Posted November 5, 2023 Posted November 5, 2023 Looking at the Honeywell Home (Resideo) API, it does appear, however, that the API would support changing of rooms. The plug-in could perhaps be modified to allow changing of the priority room (along with changing the priority type to "Pick a room"). However, I don't believe the original develop is around, and the current version that Bob put out was for conversion to PG3 only.
ISYhbsh01 Posted November 5, 2023 Author Posted November 5, 2023 On 11/5/2023 at 11:20 PM, Goose66 said: Looking at the Honeywell Home (Resideo) API, it does appear, however, that the API would support changing of rooms. The plug-in could perhaps be modified to allow changing of the priority room (along with changing the priority type to "Pick a room"). However, I don't believe the original develop is around, and the current version that Bob put out was for conversion to PG3 only. Expand Thanks
