cwagner2401 Posted November 8, 2023 Posted November 8, 2023 both are iPhones - one iPhone 14 on iOS 16.6.1 the other iPhone 11 pro max on iOS 16.6.1 updated the iPhone 14 first and 2 problems exist 1) the favorites icons are no longer formatted on the screen propery 2) when turning a device on - the device goes on but the app doesn't show that it's on so you can't turn it off. If you go back one screen and then return to the screen with the device you just turned on, it shows on and can be turned off. INTERESTING TO NOTE: the iphone 11 wasn't updated and was fine and showed the light status properly. However once updated, the iPhone 11 exhibits the same bad behaviors Can I go back to the previous UD Mobiule version? Thanks.
Javi Posted November 8, 2023 Posted November 8, 2023 Thanks for the report, I'm submitting version 1.1.36 now which should correct most of the issues. Note that Favorites have been completely rebuilt to accommodate custom views so some things may be slightly different.
cwagner2401 Posted November 9, 2023 Author Posted November 9, 2023 Update: 1.1.36 is failing in the same manner
Javi Posted November 9, 2023 Posted November 9, 2023 If the device are scenes, it is fixed in 1.1.37, which has already been submitted for review. This was reported earlier this morning.
cwagner2401 Posted November 9, 2023 Author Posted November 9, 2023 They aren't scenes. They are scene controllers but they are not scenes.
Javi Posted November 9, 2023 Posted November 9, 2023 May be related. Please let me know if issue persists on 1.1.37
dbwarner5 Posted November 9, 2023 Posted November 9, 2023 Am on 1.1.37... all my formatting, which I spent hours on through different screens is now all messed up.. Cells that are two wide, wont let a one wide appear next to it. so everything is now offset and pushed down. I hope you un fix whatever has happened.
Javi Posted November 9, 2023 Posted November 9, 2023 28 minutes ago, dbwarner5 said: Am on 1.1.37... all my formatting, which I spent hours on through different screens is now all messed up.. Cells that are two wide, wont let a one wide appear next to it. so everything is now offset and pushed down. I hope you un fix whatever has happened. Please send me a PM or open a ticket and include the UDM backup file and I will take a look. If using a ticket the file must be zipped before attaching. Someone else sent a backup with the same issue. Will update as soon as I locate the issue. 1
Javi Posted November 9, 2023 Posted November 9, 2023 Favorites cell widths fixed in version 1.1.38, will submit by end of day. 1
DSchaffer Posted December 21, 2023 Posted December 21, 2023 Right after activating the Wifi option on the eisy my wife's UD mobile is acting similar to what is described above. Both our phones login under the same account. My UD mobile works, but her UD mobile does not on her phone. Delete , re-installed, and repeat. Does not function properly (e.g. Icon not indicating whether a device is on or off. When I am able to turn a device on, I cannot turn it off. Very odd. Happened right after turning on Wifi option on eisy and only one phone.
Javi Posted December 21, 2023 Posted December 21, 2023 On the device which is not working go to Settings-Tab > Systems > your_system_name. Do you get an error message? If not cancel any request to synchronize, then press the Test Remote Connection Button. Do you get an error message?
DSchaffer Posted December 22, 2023 Posted December 22, 2023 Javi, Thank you for your reply. As soon as I got home last night I checked my wife's phone and EVERYTHING that was wrong all of a sudden was normal. I spent hours on trouble shooting and 20 hours later no problem at all. Thanks. 1
dbwarner5 Posted December 23, 2023 Posted December 23, 2023 Havent had any problems with formatting with the latest versions. Thanks Javi. 1
