Can't add new Z-wave devices
I just attempted to add a Leviton DZPA-1 ON/OFF receptacle to my system and the system gets stuck adding a device to the Z-wave network.  I tried another device and I got the same thing.  I have other DZPA-1's in my network and I was able to add them with no trouble at all, so I know they are compatible. At this point it looks like I have lost the ability to add Z-wave devices.
I can control Z-wave devices so that would imply that the dongle is working.
I tried unplugging and re-plugging the Z-wave/Zigbee dongle and then restarting IoX, but it did not help. I'm running IoX 5.7.0.
Any suggestions?
-Rick
Did you try excluding before trying to include? Try adding with the event log open and set to level3. It might give you a hint to what is going on.
Thanks for the response. I did as you suggested, and here's what I saw:
Fri 11/10/2023 06:39:50 AM : ---- Start Adding Devices - S2 Standard ---
Fri 11/10/2023 06:39:50 AM : [ZWAVE-INCL-S2STD] Start Include with S0/S2 or non-secure
Fri 11/10/2023 06:39:50 AM : [ZWAVE-INCL-S2STD] Added 'CommandAdded' callback 0x842032ca8
Fri 11/10/2023 06:39:50 AM : Z-Wave Listening for Z-Wave devices to add to the network
Fri 11/10/2023 06:39:50 AM : [X10-RX      ] 02 52 FF 80
Fri 11/10/2023 06:39:50 AM : [             X10]       J/Status Request (10)
Fri 11/10/2023 06:39:51 AM : [X10-RX      ] 02 52 FF 80
Fri 11/10/2023 06:39:52 AM : [             X10]       J/Status Request (10)
Fri 11/10/2023 06:39:52 AM : [X10-RX      ] 02 52 FF 80
There are many more "status request" lines, but no response from a Z-wave device.
The DZPA1 was blinking amber, indicating that it was ready to be included.
Thoughts?
Edited by rick.curl
Did you press the button on the Leviton after was blinking?
I have a few of those and process I have in my notes is...
 Leviton: Include or Exclude Press hold till blink, Press again
I tried it with and without the extra tap.  No joy.
In case it was the DZPA1 at fault, I tried to add a Minoston MP20Z and it failed too.
This may or may not be helpful, but I'm not sure the Minoston is a good test.  I have had a ton of problems adding Minoston devices unless they are really close to the dongle, both the Zmatter and the Zooz 700 series.
