ELK & EISY - Is there an easier way to use on the UD Mobile APP?
midrar
Go to solution Solved by dbwarner5,
So I finally upgraded to the EISY. Installation was smooth including the ELK integration. My issue now is trying to find out the easiest way to arm/disarm the alarm and check status.
When using the UD Mobile app, is there a way to add status to the Home page?
Is there a easy high level way that I can tell the status of my alarm without having to drill down to Devices and then Area?
Can I change colors to signify Armed/Disarmed?
Link to comment
Yes, you can do all of that and more. You can create a favorites page and open the app right to that page. You need to spend some time reading and understanding the user manual located here:
https://wiki.universal-devices.com/index.php?title=UD_Mobile
Link to comment
forgot to mention, that under the Configure tab of that icon, I have set the following. This makes it green. I have all my favorites display green if they are in the state I like them in, and red if not.
Also for the colors, they have to be inputed currently in ASCI format. here a web site with the codes: https://www.ascii-code.com/html-color-names
Edited by dbwarner5
Link to comment
