2412N and other Insteon controllers
Is it safe to play with a SmartLinc 2412N device in an ISY house?
When I first started using my ISY, I believe I caused some of my own grief by running PowerHome. I just acquired a 2412N as part of a lot of used Insteon gear I purchased. I have no idea if I even WANT to use it, but sure don't wanna mess up my working ISY config.
Neither the ISY nor the SmartLinc will mess with each others' links in normal operation, so you should be good.
If you restore a device for some reason using the ISY, only the ISY's links will be restored so you'd need to manually re-link the SmartLinc scenes to that restored device.
