jec6613 Posted February 11, 2024 Posted February 11, 2024 No, but the Home Assistant minimums assume you're running, "On the Iron," so it's loading up a bunch of drivers - virtualized, its memory needs are more modest.
stevesreed Posted February 12, 2024 Posted February 12, 2024 (edited) On 2/11/2024 at 12:23 AM, mapeter said: What are people's experiences with the RAM setting? Is 1GB good enough for HA? Will specifying 2GB steal too much from IoX and PG3? Expand I have not set up the HA VM yet, but I checked HA running on my PI4, and it's using 1.5G, so I'll probably set the VM to 2G. The eisy only has 8G, and since I don't have any node running, it's currently using only 3.4G. so there should be room to borrow 2G. Ideally, I'd like to give even more memory to HA, since most of my complex automations are run from HA (node red is super powerful compared to if-then programs on IoX) @Michel Kohanim A large portion of the 3.4G memory usage on eisy seems to be from the node server. If I don't have any nodes, is that something I can disable, or does it always have to be running for IoX to work? Edited February 12, 2024 by stevesreed
Michel Kohanim Posted February 13, 2024 Posted February 13, 2024 @stevesreed, By memory, I am assuming you mean RAM. If you don't want to run any plugins, you can disable PG3: sudo service pg3 stop In /etc/rc.conf, you can then set: POLYGLOT_ENABLE="NO" With kind regards, Michel 1
stevesreed Posted February 14, 2024 Posted February 14, 2024 (edited) On 2/13/2024 at 3:12 PM, Michel Kohanim said: sudo service pg3 stop In /etc/rc.conf, you can then set: POLYGLOT_ENABLE="NO" Expand Thanks. That kills the node process, but editing rc.conf does not seem to stop it from restating on the next reboot. though the overall memory usage seems to be down now. I'll see if it goes up over time. last pid: 4593; load averages: 0.19, 0.16, 0.08 up 0+00:05:27 07:01:41 41 processes: 1 running, 40 sleeping CPU: 0.0% user, 0.0% nice, 0.1% system, 0.0% interrupt, 99.9% idle Mem: 184M Active, 98M Inact, 23M Laundry, 599M Wired, 6730M Free ARC: 123M Total, 21M MFU, 89M MRU, 219K Anon, 1447K Header, 8165K Other 85M Compressed, 210M Uncompressed, 2.48:1 Ratio Swap: 4096M Total, 4096M Free PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 1898 isy 30 20 0 256M 86M nanslp 2 0:08 0.63% isy-freebsd-x64 2636 isy 1 20 0 31M 18M select 2 0:00 0.05% mosquitto 1206 nobody 1 20 0 20M 7716K select 0 0:00 0.04% mosquitto 3430 polyglot 11 20 0 4459M 124M kqread 2 0:01 0.03% node 3469 admin 1 20 0 14M 3764K CPU2 2 0:00 0.02% top 1549 root 6 52 0 81M 15M uwait 1 0:00 0.01% udx-freebsd-x64 1186 ntpd 1 20 0 21M 5396K select 2 0:00 0.01% ntpd 3192 Edited February 14, 2024 by stevesreed
stevesreed Posted February 14, 2024 Posted February 14, 2024 On 2/2/2024 at 9:13 PM, ndfan77 said: That I suspect issuing a "pkg refresh -f" will fix it (the right way). Expand I'm stuck on the no package available issue as well. I tried "sudo pkg refresh -f", but I get: "pkg: unknown command: refresh" So I'm stuck.
Michel Kohanim Posted February 14, 2024 Posted February 14, 2024 @stevesreed, Apologies, I forgot that udx service starts/stops this service. With regard to refresh, What's pkg refresh? I have never seen that before and it's not a command for pkg. Do you mean: pkg update With kind regards, Michel
stevesreed Posted February 14, 2024 Posted February 14, 2024 I was trying the suggestion from @ndfan77, to get past the issue without renaming the /usr/local/etc/pkg to get past the no packages available issue when running the script. pkg: No packages available to install matching 'vm-bhyve' have been found in the repositories pkg: No packages available to install matching 'edk2-bhyve' have been found in the repositories pkg: No packages available to install matching 'wget' have been found in the repositories pkg: No packages available to install matching 'qemu-tools' have been found in the repositories
Michel Kohanim Posted February 14, 2024 Posted February 14, 2024 I am not sure I understand why you wouldn't have the correct pkg repos. vm-bhyve is a very well known package from FreeBSD repo. Have you changed those? If not, are you sure you have access to the internet? With kind regards, Michel
ndfan77 Posted February 14, 2024 Posted February 14, 2024 (edited) On 2/14/2024 at 5:14 PM, stevesreed said: I'm stuck on the no package available issue as well. I tried "sudo pkg refresh -f", but I get: "pkg: unknown command: refresh" So I'm stuck. Expand That's embarrassing. I'm either losing it or getting a little "command dyslexic". I searched my Eisy command history for "pkg refresh" and came up empty. I searched the command history on my separate sandbox FreeBSD vm and found quite a few: pkg update -f Maybe try that? P.S. Glad I'm not the only one with psuedo communication errors when invoking pkg...! Edited February 14, 2024 by ndfan77
ndfan77 Posted February 14, 2024 Posted February 14, 2024 On 2/14/2024 at 5:44 PM, Michel Kohanim said: I am not sure I understand why you wouldn't have the correct pkg repos. vm-bhyve is a very well known package from FreeBSD repo. Have you changed those? If not, are you sure you have access to the internet? With kind regards, Michel Expand He's apparently got the "wonky" pkg repository database problem too (that isn't a communication issue). I'd bet a steak dinner that if he does this it straightens out: sudo bash mv /usr/local/etc/pkg /usr/local/etc/pkg.temp pkg search wget mv /usr/local/etc/pkg.temp /usr/local/etc/pkg pkg search wget exit But it'd be interesting to know if "pkg update -f" has a positive effect first.
Michel Kohanim Posted February 14, 2024 Posted February 14, 2024 @ndfan77, I need to know the contents of: cat /usr/local/etc/pkg/repos/FreeBSD.conf With kind regards, Michel
stevesreed Posted February 14, 2024 Posted February 14, 2024 { url: "http://pkg.FreeBSD.org/${ABI}/latest", enabled: yes, priority 1 }
stevesreed Posted February 14, 2024 Posted February 14, 2024 On 2/14/2024 at 5:55 PM, ndfan77 said: But it'd be interesting to know if "pkg update -f" has a positive effect first. Expand "sudo pkg update -f" fixed the issue for me. Thanks!
ndfan77 Posted February 14, 2024 Posted February 14, 2024 (edited) On 2/14/2024 at 6:03 PM, Michel Kohanim said: @ndfan77, I need to know the contents of: cat /usr/local/etc/pkg/repos/FreeBSD.conf With kind regards, Michel Expand My issue with pkg (which was doing exactly what @stevesreedquoted above) straightened out immediately after I did the temporary rename of /usr/local/etc/pkg reported here (and has been fine since). Here's the contents of my FreeBSD.conf: P.S. It was only my second (follow-on) post that mistakenly referenced "pkg refresh -f" instead of "pkg update -f". I just corrected it. Edited February 14, 2024 by ndfan77 1
Michel Kohanim Posted February 14, 2024 Posted February 14, 2024 @ndfan77, Please try : curl -s https://pkg.FreeBSD.org and let me know what you get. With kind regards, Michel
ndfan77 Posted February 14, 2024 Posted February 14, 2024 On 2/14/2024 at 6:34 PM, Michel Kohanim said: @ndfan77, Please try : curl -s https://pkg.FreeBSD.org and let me know what you get. With kind regards, Michel Expand
Michel Kohanim Posted February 14, 2024 Posted February 14, 2024 Great, now: sudo pkg update -f With kind regards, Michel
ndfan77 Posted February 15, 2024 Posted February 15, 2024 On 2/14/2024 at 8:14 PM, Michel Kohanim said: Great, now: sudo pkg update -f With kind regards, Michel Expand
stevesreed Posted February 15, 2024 Posted February 15, 2024 Quick update: After using pkg update -f. I ran the script again, modified for 4GB memory and 500G disk space, and it worked perfectly. I restored a current back up from the RPi4 HA setup and it worked perfectly. All integrations, including HACS integrations, and add ons, automations, etc. just worked, no adjustments needed. And HA seems faster than previously on the RPi4. I've now removed the RPi from my network altogether, and have IoX and HA running on eisy for a nice, clean, one box solution. Very cool! 1
Michel Kohanim Posted February 15, 2024 Posted February 15, 2024 @ndfan77, This is great. What's the issue now? With kind regards, Michel
ndfan77 Posted February 15, 2024 Posted February 15, 2024 On 2/15/2024 at 2:51 PM, Michel Kohanim said: @ndfan77, This is great. What's the issue now? Expand I don't believe there is one other than whether "pkg update -f" should be added to the helper script before the "pkg install ...." statement: echo "Refreshing package databases..." pkg update -f echo "Installing necessary packages..." pkg install -y vm-bhyve edk2-bhyve wget qemu-tools
Michel Kohanim Posted February 15, 2024 Posted February 15, 2024 Ah, I see. Thank you for the suggestion and I agree! With kind regards, Michel
carealtor Posted February 16, 2024 Posted February 16, 2024 @Michel Kohanim What would be the possibility that eisy might be offered with Home Assistant already preinstalled? This would probably motivate me to upgrade from my Polisy.
Michel Kohanim Posted February 16, 2024 Posted February 16, 2024 @carealtor, It's possible but I am not sure how to deal with support as we are (nor do we have resources) to address HA installation/configuration issues. Also, considering the cost of NVMe to be at least $74, it would make the cost of eisy astronomical. But if there's enough demand, we'll definitely consider. With kind regards, Michel 1
carealtor Posted February 17, 2024 Posted February 17, 2024 On 2/16/2024 at 5:18 PM, Michel Kohanim said: @carealtor, It's possible but I am not sure how to deal with support as we are (nor do we have resources) to address HA installation/configuration issues. Also, considering the cost of NVMe to be at least $74, it would make the cost of eisy astronomical. But if there's enough demand, we'll definitely consider. With kind regards, Michel Expand Count me interested. I promise I won't ask for HA support. 😁 1
