cksedg Posted January 13 Share Posted January 13 I have three 2477S switches and one Door Sensor all controlling the same lights. The door sensor and the primary switch work fine; but the other two switches sometimes work and other times they don't. The LED lights on the switches "flicker" and finally stop flickering, then the switch works correctly. How should I have these set up in the scene that controls them? I can't quite figure it out. Thanks!!! Link to comment Share on other sites More sharing options...
cksedg Posted January 14 Author Share Posted January 14 Never mind! It was one of the switches that was causing a problem. I factory reset it and restored it from the ISY and everything is dandy now! Link to comment Share on other sites More sharing options...
