someguy Posted February 18, 2024 Posted February 18, 2024 I’ve got my Elk M1 Gold system up and running, now I need help getting it connected to my phone and my PolISY. 1) phone app: I see four apps that seem like they will work. They all are called “ekeypad “. One even costs $140. (I’ve never seen a that costs more than $20.) are there other apps? What do you guys recommend for an app that doesn’t have recurring fees? also: to connect the Elk Nodeserver to the Elk, is it as simple as having a login to the Elk-RP2 system and using that to log in to the PG3? Thank you.
DennisC Posted February 18, 2024 Posted February 18, 2024 1 hour ago, someguy said: I’ve got my Elk M1 Gold system up and running, now I need help getting it connected to my phone and my PolISY. 1) phone app: I see four apps that seem like they will work. They all are called “ekeypad “. One even costs $140. (I’ve never seen a that costs more than $20.) are there other apps? What do you guys recommend for an app that doesn’t have recurring fees? also: to connect the Elk Nodeserver to the Elk, is it as simple as having a login to the Elk-RP2 system and using that to log in to the PG3? Thank you. Once the plugin is setup and connected, UD Mobile will allow you to arm/disarm and monitor your Elk. You don't need another app. Here are the directions for installing and using the Elk plugin: https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/README.md When you setup the plugin, create a dedicated Elk user code for the plugin. You can not have the plugin and Elk-RP2 connected at the same time. They both use the non secure port to communicate.
