February 21, 20242 yr Yesterday, the “B” button on an 8-button KPL (2334-222) disappeared from the device tree but the other buttons remained in the tree. Ultimately, I have factory reset the KPL three or four times as I have tried to get the button back in the device tree. Now, the KPL and all its buttons have disappeared from the device tree! Fortunately, I can still use previously created Alexa commands to control most things. And, where buttons on other keypads overlap I can use those as well. It appears I may have a dead keypad. I am nearing age 80, and I don’ t want to face the challenge of replacing the KPL unless I have no choice. Any suggestions are welcome.
February 21, 20242 yr Author It is running on a MacBook Pro 2019, Sonoma 14.3.1, ISY 994/IR Pro. v. 4.9.0
February 21, 20242 yr Author I tried to relink the KPL twice. No soap. I got the message about insteon engine. I believe it is dead given the way one KPL button disappeared first then the device and, finally the remaining buttons. I used the link new device feature. Thanks. i have ordered a replacement.
February 22, 20242 yr 14 hours ago, smokegrub said: I tried to relink the KPL twice. No soap. I got the message about insteon engine. I believe it is dead given the way one KPL button disappeared first then the device and, finally the remaining buttons. I used the link new device feature. Thanks. i have ordered a replacement. That should not have erased it from your ISY though. For example, I have zero insteon devices connected in my home. My polisy is still connected so I can test Ra3 devices for @bpwwer. It still shows all of my insteon stuff regardless of communication. The message you received normally occurs when the address is mistyped. If you try start linking, and use the set button, that will avoid incorrect address issues. Edited February 22, 20242 yr by lilyoyo1
