Accessing Admin UI through portal/cloud
The ISY Web access will bring up the lists of devices, and so on, and the UI app works fine, so something is working.
So I ferreted out the my.isy.io ..../desc url from the ISY information dialog.
Put that in the ISY finder, it populated with the "cloud" address entry, got the usual Admin UI credential request, put that in, but it failed. Yes, I doubled checked it.
I then (after 3 tries) got just a blank Admin UI.
Wonder what I'm doing wrong?
Do I use the portal login instead?
Is there some setting needed?
* Orest
Edited by oskrypuch
Solved by Geddy
