Notification Corruption
I recently added notifications to the mobile app and PG3 and it seems to have corrupted the notification system.
I’ve put this in the PG3 Notification section of the forum – hopefully this is the right place.
Prior to making this update, my notifications did work properly. Once I made the update, all of my existing notification content (Burglar Alarm, Fire Alarm, etc.) were replaced by “Response Type2”.
If I go to If/Then, I am not able to use the “Remove Line” button to delete “Response Type2” and make changes.
If I go to “Customizations” to add new content, I am unable to add new content as clicking  the box does not do anything.
I’ve attached a copy of the error message that shows within the Mobile app if I try to add a notification there.
I’ve also attached a screenshot of the PG3 notification installation.
Is there a way to fix this? Or, will I need to go back to a backup to start over with this?
Are you on eisy or Polisy?
What firmware are you running?
Are you on the latest UD Mobile?
Have you tried rebooting eisy/Polisy?
@DennisC
I'm on eisy running the current firmware version 5.8.0
I am on the latest UD Mobile
I have rebooted the eisy via Configuration / eisy System Settings / Reboot
