Can I use TTS with eisy and Alexa
I was wondering if it's possible to have a program send a text to speech command to my Alexa. For instance when I run a program from a speech command thru my Alexa if it sees a certain variable value it would speak a TTS line back thru the Alexa.
Thanks in advance
Joe
You can use a variable or other device to trigger a routine on Alexa that has your TTS setup.
