More traffic in Event Viewer
Could some one please shed some light on this traffic:
Sat 04/20/2024 09:02:36 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:03:05 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:03:21 PM : [n008_setup      ]      DOF   0
Sat 04/20/2024 09:03:33 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:03:45 PM : [            Time] 21:04:07 0(0)
Sat 04/20/2024 09:04:02 PM : [D2D EVENT       ] Event [n007_keypad_1] [GV10] [0] uom=0 prec=-1
Sat 04/20/2024 09:04:02 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:04:15 PM : [            Time] 21:04:37 0(0)
Sat 04/20/2024 09:04:31 PM : [D2D EVENT       ] Event [n007_keypad_1] [GV10] [0] uom=0 prec=-1
Sat 04/20/2024 09:04:31 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:04:45 PM : [            Time] 21:05:07 0(0)
Sat 04/20/2024 09:04:59 PM : [D2D EVENT       ] Event [n007_keypad_1] [GV10] [0] uom=0 prec=-1
Sat 04/20/2024 09:04:59 PM : [n007_keypad_1   ]     GV10   0
Sat 04/20/2024 09:05:04 PM : [D2D EVENT       ] Event [n007_controller] [DOF] [0] uom=0 prec=-1
Sat 04/20/2024 09:05:04 PM : [n007_controller ]      DOF   0
Sat 04/20/2024 09:05:09 PM : [D2D EVENT       ] Event [n008_8b4c010007aa53] [CLITEMP] [-158] uom=4 prec=1
Sat 04/20/2024 09:05:09 PM : [n008_8b4c010007aa53]  CLITEMP -158 (uom=4 prec=1)
Sat 04/20/2024 09:05:09 PM : [D2D EVENT       ] Event [n008_8b4c010007aa53] [CLIHUM] [548] uom=51 prec=1
Sat 04/20/2024 09:05:09 PM : [n008_8b4c010007aa53]   CLIHUM 548 (uom=51 prec=1)
n007 is Elk plugin and n008 is Yolink plugin.
And here is a part from PG3 Elk log:
val=0 force=False
2024-04-20 21:04:54,059 ELK-35682  udi_interface      DEBUG    BaseNode:set_driver: keypad_1:Keypad 01: GV3,0 default=None force=False,report=True
2024-04-20 21:04:54,059 ELK-35682  udi_interface      DEBUG    Keypad:send_driver: keypad_1:Keypad 01: reportCmd(GV10,1.2)
2024-04-20 21:04:54,065 Thread-1   udi_interface.interface DEBUG    interface:_send: PUBLISHING {'command': [{'address': 'keypad_1', 'cmd': 'GV10', 'value': '1', 'uom': 2}]}
2024-04-20 21:04:54,092 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message command
2024-04-20 21:04:54,092 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING command
2024-04-20 21:04:54,092 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS command message {'address': 'keypad_1', 'success': True} from Polyglot
2024-04-20 21:04:58,216 MQTT       udi_interface.interface DEBUG    interface:_message: QUEUING incoming message shortPoll
2024-04-20 21:04:58,216 Command    udi_interface.interface DEBUG    interface:_parseInput: DEQUEING shortPoll
2024-04-20 21:04:58,216 Command    udi_interface.interface DEBUG    interface:_handleInput: PROCESS shortPoll message {} from Polyglot
2024-04-20 21:04:58,217 Thread-448 udi_interface      DEBUG    Controller:handler_poll: start
2024-04-20 21:04:58,217 Thread-448 udi_interface      DEBUG    Controller:shortPoll: start
2024-04-20 21:04:58,217 Thread-448 udi_interface      DEBUG    Area:shortPoll: area_2:Area Bypass: ready=True poll_voltages=False
2024-04-20 21:04:58,217 Thread-448 udi_interface      DEBUG    Area:shortPoll: area_1:Area 1 Driv: ready=True poll_voltages=False
2024-04-20 21:04:58,217 Thread-448 udi_interface      DEBUG    Controller:shortPoll: done
Maybe the wiki information would help:
https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Using_the_Event_Viewer
Otherwise, what specific question do you have? Event viewer is usually only used in troubleshooting steps. Are you having other issues that you could describe and get help with?
Or are you just generally inquiring about the event viewer information?
