May 19, 201015 yr Anything with a browser will work. I've used a Motorola Q before, but the experience is most definitely less than optimal. I currently use a Droid with the ISYAjax web interface and it works quite well. I resume that it would work on any device that supports Javascript, but is optimal on touchscreen devices.
March 25, 201313 yr I want to access ISY from outside of network in which it is connected.Any suggestion please.
August 25, 201312 yr I want to access ISY from outside of network in which it is connected.Any suggestion please. Sorry, I'm new to this forum and just read your post. Not knowing if you have resolved this or of your knowledge of firewall/port forwarding the only setting that needs to change in the ISY is File>Enable Internet Acess then forward a port on your firewall to
August 26, 201312 yr bmartinette, You do not need to do File | Enable Internet Access if you are creating port forwarding rules in the router. It's an either/or thing. With kind regards, Michel
August 26, 201312 yr Michel, Is port 443 open without "enable internet access" or would you just be forwarding to port 80?
August 26, 201312 yr Both 443 and 80 are open on the ISY by default. You can change the port numbers if you need to. You should only forward the SSL port (443 or whtever you change it to) and use port 80 only inside your lan. The Enable Internet Access is a UPNP feature that will attempt to auto configure UPNP enabled routers for forwarding and is not required is you manually forward ports. -Xathros Edited to correct spelling.
