Usable Verizon wireless devices
paulw
Anything with a browser will work. I've used a Motorola Q before, but the experience is most definitely less than optimal. I currently use a Droid with the ISYAjax web interface and it works quite well. I resume that it would work on any device that supports Javascript, but is optimal on touchscreen devices.
  • 2 years later...
  • 5 months later...
I want to access ISY from outside of network in which it is connected.Any suggestion please.
Sorry, I'm new to this forum and just read your post. Not knowing if you have resolved this or of your knowledge of firewall/port forwarding the only setting that needs to change in the ISY is File>Enable Internet Acess then forward a port on your firewall to :)
Both 443 and 80 are open on the ISY by default. You can change the port numbers if you need to. You should only forward the SSL port (443 or whtever you change it to) and use port 80 only inside your lan.
The Enable Internet Access is a UPNP feature that will attempt to auto configure UPNP enabled routers for forwarding and is not required is you manually forward ports.
Edited to correct spelling.
      378.8k
