Openweather all 0's
Go to solution Solved by Ross,
@apostolakisl Have you upgraded from One Call 2.5 tp 3.0?  OpenWeatherMap deprecated 2.5 in June.  @bpwwer released version 4.0 of his plug-in to work with One Call 3.0.
It's not all that clear on their website, but the free version provides 1,000 calls per day.  You can set your limit (change it from 2,000 to 1,000) so you don't go over this number and get charged.
If you've already done the above, then I'm sorry - your issue is over my head!
Ross
Ross
As is usual for these things, it is as clear as mud.  I subscribed to the 3.0 version and gave them my cc info and they say it is active.  But I still get all zeros.  I am still using the same key and as far as I can tell, that is the key you use.  I restarted the node a couple times and still all zeros.  I will give it some time to activate perhaps.
You need to generate a new key, key's for previous plans/subscriptions won't work with the OneCall 3.0 subscription plan.
Turns out, at least in my case, I didn't.  After about 10 minutes, it started working with the same key.
      380k
