wrj0 Posted August 12 Posted August 12 Started getting an error when trying to launch UD Mobile on my iPhone 13 Pro Max ver 1.1.73. Seems to have started after I did a iOS update to 17.6.1. Can't get to any settings or devices before the app presents: Error, Restarting Connection. I did manage to quickly capture a more detailed error that presented: Login to the portal is working fine. And, UD Mobile on my iPad running the same iOS and UD Mobile versions is working fine. Suggestions on how to resolve this error, please.
Javi Posted August 12 Posted August 12 The Portal Login is no longer valid. Try going to the UDM Account settings, does it force a login?
wrj0 Posted August 12 Author Posted August 12 (edited) Thanks, Javi. Can't get to the UDM Account Settings, before the screen refreshes with the Error, Restarting Connection. And, returns to the home screen. Edited August 12 by wrj0 more info
Javi Posted August 12 Posted August 12 The following are not available? The top menu (3 dots) > My Account Or Settings Tab > App Settings > Accounts
wrj0 Posted August 12 Author Posted August 12 Yep, the 3 dots are there, and if I click on them, I can briefly see My Account. But, before I can do anything, the screen quickly goes back to the home page and shows Error: Restarting Connection.
Javi Posted August 12 Posted August 12 I can not replicate this behavior. Can you capture a short video showing the refresh? When I force the app to restart connection the menu does not disappear.
wrj0 Posted August 12 Author Posted August 12 (edited) Thanks for investigating, Javi. Attached is a video capture of my pressing the 3 dots on the main page, then trying to click on My Account. The page goes back to the main page before I can complete the access to My Account. Then the page refreshes every ~3 sec with the Restarting message. Edited August 12 by wrj0
Solution Javi Posted August 12 Solution Posted August 12 Replicated, thanks. It looks like something changed in the recent iOS update, the app is trying to push the user to login but can not launch the view so it restarts at Home Tab. I don't yet have a fix and can only test on the emulator as I left my iPhone cable at home. Please try to disable WiFi and Cell network which should give you time to get to the Account Settings before refresh. Finally re-enable the Mobile Device's network and login. If the refresh happens before you can login, remove the Account (trash icon) from UDM on UDM's Account screen. Then go to the Controller's settings and login when prompted. I'll push an update as soon as I can verify a fix, but could be 24 - 48 hours before approved by Apple. 1
wrj0 Posted August 12 Author Posted August 12 Thanks again! Turned off wifi & cellular networks - that allowed access to Settings. But, selecting Configuration - Portals, returned: "Error Not Connected to Network." But, following your suggestion to remove the Account from Settings>Accounts, then turning wifi back on, and logging in, allowed the app to recover. Well done on finding a fix for this - much appreciated.
Javi Posted August 12 Posted August 12 Great, found a permanent fix will push by end of day UDM version 1.1.74 1
