Lighting schedule
I have several different programs that turn on lights at various hours and at different levels.  If I happen to have one of these lights turned on before the program executes, then it will change the light level to that indicated by the program.
I've tried writing several programs to disable the program if the light is already on, but I have been unsuccessful.  I would appreciate help in creating a program script that would avoid this issue.
Can you post one of the programs? Ideally, you'd add an if clause to see if the light is on
Here's a sample idea
   Time is xx:xx
AND
   Status my light is 0%
  Turn on the light
Unfortunately it would have to be one light at a time using this method
Edited by paulbates
If I turn off the light during this period, the program will turn it on again.  I could try fade up, but there doesn't seem to be a max level and time frame for this option - I don't want 100%.  Thanks.
I do something similar for my back deck lights. They are "checked" into correct settings, but if I want them to STAY off, they would come back on as you said.
So I set up a trigger program that says IF light is on and is turned off, Then Decklightsstayoff =1.
Then in my original program, I add that variable to the IF statement so that it wont run if the variable is 1.
Some more needed than above to fine tune things and reset the trigger etc, but hopefully this gives you the path to go on.
If you need more, let me know and I can show some programs.
Cheers.
@haroldunger FYI - the preferred method of sharing programs is to right click on the program and select the last menu item of "Copy to Clipboard" then paste as text into your reply (make sure you use COPY and not export). I've removed your doc file and added as image, but to make it easier for those helping you on programs having the text version makes it easy to edit and highlight the changes.
The way around having the light adjust if it was already on would be to set a status with "NOT" in the statement.
This is one I have for a light that needs to stay on during the night:
Backdoor Light -
        From    Sunset  -  1 hour
        To      Sunrise +  2 hours  (next day)
    And 'Backdoor' Status is not On
        Wait  10 seconds
        Set 'Backdoor' On
Use the "Status" rather than "Control". In your situation could simply be "If {node} Status is not Off" then don't run the program. Since your time is specific to Sunset + 30 minutes it will only trigger at that time. Otherwise, can change your time From/To and if the light is turned off during that window then your program would trigger true and run the "Then" portion.
I used to run a program that would dim a light as the night went along. It would be shocking if I had the light dimmer than the initial setting (if we were watching a movie and had the lights down <30% it would suddenly run it up to 80% when the time trigger happened). I ended up splitting that program like @dbwarner5 into two programs with a status that it would only then run if the light was higher than the initial brightness.  Make sure the other program doesn't have an "IF" and I like to have it disabled. Program 1 would run the "Then" of Program 2.
Okay and thx.  I’ll reread ur email many times and try to create a program for a progressively brighter light that doesn’t all of a sudden go to/-100% from 60%, or so.
Here are the programs that I "waterfall" with. I dont have a time out, but I do have a 1am reset on these. Hope this makes sense.. I have five different settings from the same switch, in sequence.
Mbed Doug reading 1  SD - [ID 01C8][Parent 01CF]
        'MBed Reading Doug' is switched On
    And 'MBed Reading Doug' is not switched Off
        Resource 'Doug's Reading on bright'
        Enable Program 'Mbed Doug reading 2 LD'
        Disable Program 'Mbed Doug reading 1  SD'
Mbed Doug reading 2 LD - [ID 01C9][Parent 01CF][Not Enabled]
        Resource 'Doug's Reading on full bright'
        Enable Program 'Mbed Doug reading 3 LD'
        Disable Program 'Mbed Doug reading 2 LD'
Mbed Doug reading 3 LD - [ID 01CA][Parent 01CF][Not Enabled]
        Resource 'Doug's Reading on Blue Dim'
        Enable Program 'Mbed Doug reading 4 LD'
        Disable Program 'Mbed Doug reading 3 LD'
Mbed Doug reading 4 LD - [ID 01CB][Parent 01CF][Not Enabled]
        Resource 'Doug's Reading on Red dim'
        Enable Program 'Mbed Doug reading 5 LD'
        Disable Program 'Mbed Doug reading 4 LD'
Mbed Doug reading 5 LD - [ID 01CC][Parent 01CF][Not Enabled]
        Resource 'Doug's Reading on green dim'
        Enable Program 'Mbed Doug reading 1  SD'
        Disable Program 'Mbed Doug reading 5 LD'
This one resets the loop when I turn the switch off.
Mbed Doug reading Turned off - [ID 0350][Parent 01CF]
        'MBed Reading Doug' is switched Off
     Or 'MBed Reading Doug' Status is Off
        Run Program 'Mbed Doug reading off' (Then Path)
        Set 'MBed Reading Doug' Fast On
Mbed Doug reading off - [ID 01C2][Parent 01CF]
        Wait  1 second
        Resource 'Doug's Reading Off'
        Run Program 'Mbed Doug reading reset loop' (Then Path)
Mbed Doug reading reset loop - [ID 01CE][Parent 01CF]
        Time is  1:00:00AM
        Wait  2 seconds
Edited by dbwarner5
Big meal to digest here...  Please give me a bit of time to understand what you have done.  Thank you very much.
Again, this is for a hue spot light in the ceiling. the switch is an Insteon switch. Switch is always on to give power to the hues. Insteon program turns it back on, if turned off, after turning hte hue off.
Sorry for not yet responding...
Having been having a major issue with a new PLM that is failing - just replaced it.
Will get back to working with the lighting programs shortly.
Thx again.
  • 3 weeks later...
Still troubleshooting...
According to Verizon, it might not be the PLM, nor the EISY, nor my programming.  It might be that the Verizon FIOS "channel" is not through putting a clean strong signal to my home due to congestion.  So Verizon switched my channel to a less used one that was supposed to cure the numerous issues.  Waiting to see if they are correct...
BTW, Michel and his team have been wonderful trying to help me track down the problem.  It has been nothing short of frustrating for all of us.
So, please stay tuned.  Once I'm back, I'll start testing the program that was the reason for starting this entire string.
Edited by haroldunger
Oh, one good thing came out of this frustration.  Most of the bulbs I had tried had some flicker when running at <100% brightness or a periodic "flick" when running at 100% brightness.  I was about to install capacitators sold by Insteon to maintain a constant load on the switch, and, theoritcally, solve the problem.
But, at the last moment, I was pointed to Murray Feit BR30 bulbs with variable Kelvin temperatures (switch on the bulb) and different flood diameters on the PAR30 bulb (again a switch on the bulb).  They worked - essentially no flicker/flick and smooth 10%-100% brightening.
Yippee!!!!
  • 1 month later...
Unfortunately, still not back.  We haven't yet resolved the crash problems.  Please stay tuned or add comments if anyone has any ideas.
We've been working with Michel.  We've ruled out Verizon Fios because we've placed a Dream Wall between the Verizon modem and the entire system and it shows that Fios has not gone down.
We're not giving up!
  • 2 months later...
  • 1 month later...
Since everything seems to be working properly and the log shows minimal errors, I'm back to trying some programming to turn on certain lights at sunset +"x' random minutes or +/-6pm +"x' random minutes if sunset is later (spring/summer) and visa versa if sunset is earlier (fall/winter) following dbwarner5 examples.  Tonight will tell the tale.
