Kasa Devices to support
I installed 3.2.2 in a new slot.  Seems to be stuck in a loop with this error:
2024-12-22 16:31:31.319 MainThread udi_interface ERROR udi_interface:write: No module named 'mashumaro'
I created a debug log file (maybe) should I attach it here or send another way?
Must have been an install error, please "Download Log Package" and PM it to me.
Now it seams to be looking for:
2024-12-22 21:15:15.640 MainThread udi_interface ERROR udi_interface:write: No module named 'async_timeout'
I will send a log package.
  • Like 1
3.2.4 works. I can control the KP125M now.  The power nodes populate but the voltage and current are 0.  I don't see these in the Kasa app so I assume it doesn't report them.
Thank you.
Thank you.
Awesome!  Glad its finally working.  The new library has the ability to query features supported by the device so I need to do some rework on how I create the node so it properly shows the features it supports, like voltage and current.
  • 1 month later...
I'm jumping back into this thread after a couple of months.  I'm still disconnected.
I have bought the Production store Kasa (Standard - Perpetual) twice (and have been charged $30 twice) and yet I am still receiving the following message: "The subscription for this node server has expired."  So, I'm a bit gun shy to install it yet again (and get charged again).
When I go into the Production store, I only see 3.1.4 available.  I don't see 3.2.4.  I see the same thing in the non-production store.
I am running an ISY (v 5.3.4) and using a Polisy (v 3.1.13) for the plug-ins.
Thank you as always,
Ross
http://d2z8ydsemzif1x.cloudfront.net/monthly_2025_02/image.png.837547ef3ed4e972fad124a9c105c5ba.png
Ross
Please open a support ticket and send this in along with the uuid of your polisy
Sent from my Pixel 8 Pro using Tapatalk
  • Like 1
Posted (edited)
@Jimbo.Automates
I believe I now have the correct version - 3.2.4 [beta].  Thank you to @bmercier.
However, it is still disconnected.  I notice the last line of the log says:  No module named 'mashumaro'
I'm attaching the log and the log package as I saw that @mjrush had the same issue and you asked him to do the same:
Thank you in advance for any and all assistance,
Ross
Kasa_2-18-2025_72144-PM.zip Kasa_2-18-2025_72145-PM.zip
Edited by Ross
  • 1 month later...
@Ross
I can't control subscriptions, you'll need to submit a support ticket.
For the error: No module named 'mashumaro'
This means the install failed, please reinstall in the same slot then "Download Log Package" which will show the install error, and PM that to me.  You likely have a problem that support will need to look into.
Sorry for not responding previously, I try to monitor the forum but don't always get notifications.  The beta fixes many issues and I'll try to release soon.  Just remember, this is a side job for most developers so real work and life do take priority.
@Jimbo.Automates Thank you.  I only see version 3.1.4 available.  And I've read there's a 3.2.2 version around.  I probably need to update my Polisy (I run the ISY and have my plug-ins on Polisy).  I'll look into this in about 3 weeks as I am traveling off/on for a bit.  Hopefully this forum remains open until then!
And, I do appreciate that this is a side job for you and also appreciate what all plugin developers do for us users.
Thanks again,
Ross
  • Like 1
  • 4 weeks later...
Hello Jimbo,
I recently deployed a few EP25 plug modules.  These or the WiFi,Bluetooth, HomeKit supported variety.  The KASA app recognizes them as do Apple HomeKit, Alexa and Google.  The KASA Plugin for PG3 does not seem to see them.  Could support for these be added without too much trouble?
Thanks in advance and let me know if there is anything I can provide to assist.
-Xathros
Hello Jimbo,
-Xathros
Please try the beta in a new slot. I'll try to release it soon. Been too busy buying a new home and trying to prepare and sell our current home and move to a different state.
Jimbo,
I am running eisy with current software.
PG3x Version 3.3.18
Status: Connected
Frontend Version: 3.3.18
IoX Version: 5.9.1   Connected
It is primarily Insteon but I recently added KASA support with your node server.
My system works well but with the following issue.
I have some older HS200 that are Hardware version 5 and firmware 1.0.11
I just installed a newer HS200 that is Hardware version 6.6 and firmware 1.0.3 Build 240723 Rel 192630
Both identify as current firmware.
When running the KASA production node server 3.1.4, everything else is fine including a few dimmable Kasa HS220. But the new HS200 is not found.  I cannot add it by IP or by name in the Polyglot interface and the node server doesn’t discover it.  I was able to add it in the ISY configuration under Plugins using the device id and the controller id and it appears, but it doesn’t work.
As a test, I loaded and ran the current beta version.  I added the Kasa login information and the newer HS200 was discovered and ran great.  Unfortunately, none of my HS220 dimmable switches are discovered in the Beta set up.
Am I missing something in setup or is there a difference in the production vs Beta?
Tom
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
      37.9k
      378.3k
