The node servers are not connecting.
The node servers stay in disconnected state.
Thanks for any suggestions. Rebooted many times.
Update: I did a reinstall of all plugins and that seemed to work.
Edited by garybixler
@garybixler glad you got it sorted out by running the reinstall all plugins.
Question though. Had you updated recently or done something that could have caused them to be in a disconnected state? While fixed now, it might be that this should be reviewed by UD (certainly if it happens again).
What plugins are you running that were staying disconnected? Just list a few if you've got a lot running.
I was shutting down the eisy with 6 clicks of the power bottom, but I probably missed doing 6 so I tried 6 again and then after that the node servers stayed disconnected. So basically my fault. Glad there was a reinstall plugins button. Reloaded each node server maintaining the configuration settings.
