Nest not working and can't find in plugin purchases or plugin store
Hi,
Hi @Goose66 & @Michel Kohanim
I noticed that my nest devices were not updating in iox and when I check the plugin it is disconnected.  I've tried restarting, no change and nothing appears in the log even on debug setting.  I've tried to authenticate again and that seems to run fine but still no connection and nothing in the log.  I then noticed that the NestSDM does not appear in the store or my purchases.  Is this no longer available?
Solved by Geddy
@joeria cool. But know that since it's in the non-production store it could have some testing that is being worked on so probably keep a close eye on it for any issues. It sounds like there was some issues with Google based on reading other posts in this area of the forums. Hopefully they're being worked out.
This is still on the to-do list, but the steps were daunting (and potentially expensive) and I had other lower-hanging fruit to go for. If anyone wants to use in the meantime, I encourage you to setup your own Google Developer account and Google Device Access project to use. The instructions in the plugin release notes are detailed and refined.
