Lost fast off and fast on function for all switches
Noticed that one of my switches did not work with fast off and on.
Tried another switch controlling other lights and also did not work.
Reset the switch and still did not work.
Setup a new fast off scene on a different switch and it did not work.
Restore the device in the ISY software and it did not work.
Ran tools-diagnostics-show device links table
Have not revised anything recently in the system
Can anyone see an issue from this? What next?
Edited by 62vetteefp
Solved by paulbates
How old is your PLM. There'll be a sticker with 4 digits on the back that can be decoded here if you don't know.
Try unplugging and replugging the PLM and retesting... If things start working it will mean the PLM is starting to die.
Also, can you post an image of the PLM links table; how many links are in it and how many devices do you have?
35 minutes ago, paulbates said:
Also, try a "restore device" on the one example you gave and retest.
Forgot to write that down. I did a restore on the switch in the program. Did not correct the issue.
Is the bottom chart the link table you are asking for?
PLM 2413 S V2.2 1622
ISY UD 994 sn 0016279
Un plugging and replugging did not fix it.
Ok, pressing and holding for 5 seconds factory reset the switch, wiping out its link table. You need to go into the admin console, pick the device and "restore device"
Just unplugged the PLM and plugged back in and then restore device the switch. Still not working.
@62vetteefp
The problem is not with your PLM or your ISY
Your firmware and UI must be the same version. Your screenshot shows your firmware at 4.9.0 and your UI at 4.7.3. You need to clear your java cache, be sure to check all three boxes, then download the IoX Launcher from here. This will update your UI to 4.9.0
https://isy.universal-devices.com/start.jnlp
15 minutes ago, Techman said:
@62vetteefp
So both say 4.9.0 now and none of my switches will fast tap work. I did a restore switch after also.
A PLM with only 2 links is a broken PLM, there should be at least dozens of links. 1622 means week 22 of 2016, a period when PLMs had the bad capacitor issue.
I don't disagree with @Techman on aligning FW/UI versions, but your PLM is on borrowed time.
tried the links again and only the same two. So ordered a new PLM. Will see!!
Thanks all!!!
6 minutes ago, Techman said:
I agree with @paulbates, guess I missed your screenshot of the PLM.
@62vetteefp Have you tried a restore PLM
So I went to  tools diagnostics PLM /info status and it did some kind of update. Is this a PLM restore?
Still does not work.
3 minutes ago, paulbates said:
No. Restore PLM will be on the file menu. If it does help, it will be temporary.
Did it. Same issue!
One last thing to try - remove power from the PLM and the ISY. Wait about 30 seconds then power up the PLM, wait about 15 seconds then power up the ISY
Make sure isy is powered off and the new PLM is plugged into the correct port on the isy. Then power up isy. Once logged in, choose restore plm> restore devices
Your PLM information. Indicates it is fairly old. Also with only two links. I would suspect the PLM is failing. As two links is way to low.
Just got the new PLM and before I replaced it everything started working again. Here is the latest PLM links table. Seems back to normal.
Correct it's on it's way to dieing.  I think it was mentioned above. It will fade away in and out until it dies for good. Now is your chance to replace it in your terms
Edited by paulbates
