Smart lock addition
drprm1
Go to solution Solved by Panda88,
Okay great! My lock is now showing up in the test node.Didn’t see what it looked like like in the AC
I’ll look forward to the production update and thanks!
Seems like the log you sent is old
Can you generate a new one - manually opening the lock and then try to control it from teh AC as well .   I am a little guessing on the control (until official API is posted)
Maybe you can try to stop the regular node server while testing
I found part of the issue with the new lock - I can likely get to retrieve data fairly easily, but controlling it may be more difficult without documentation
Pretty sure I stopped the regular node for this test...Did another log. Started test plug-in and let it find all nodes for a few minutes then I used the AC to lock, unlock, and query several times then locked and unlocked several times manually. (regular node was stopped)
Here's the log
YoLinkTest_1-10-2025_80937_AM.zip
Edited by drprm1
Updated YoLink Test to 1.3.14. I can control lock via AC fine.  Manually controlling lock or control by Yolink app the status in AC isn't updated. The node isn't updated correctly when using "update status" or "query" either.
Even though I can lock and unlock using AC it shows Nodeserver status as "not connected" and connection state as "offline"
YoLinkTest_1-13-2025_24659_PM.zip
Can you try 1.3.15
I will only pick switches and locks - The code somehow gets the online status wrong, but I cannot figure out why - added some more debug info
Nice! Works as it should. AC status updated when changed manually or by Yolink app. Can control from AC. Shows online and connected.
(Nitpick, battery shows -1)
Appreciate your efforts
updated to 1.3.22 Dashboard shows "disconnected" If I try and start plugin a green pop up says "already running"
No log is showing
      378.2k
