Program that runs when ELK Arm/Disarm???
killervette
Can the ISY run a program when the status of my ELK alarm changes? I want to run an action on disarm. ELK cannot run the program because i will be utilizing the ISY network module.
I am using the network module to run programs based on my alarm system status changes so it can be done. Can you link the status of the Elk to a program? IOW, for my setup I created an empty program called Alarm Armed Away. Then, I linked the alarm's armed away status to the program (that's the part you have to see if you can do). That way, the status of the program is true when the alarm is armed away and false when not. Then you can write any number of programs using the status of Alarm Armed Away as the If statement.
i guess my question is where in the ISY admin can i set that up. Or are you saying you setup a program in ELK. I am the ELK RP2 software. Is that what you are using?
also, the "program" that i want to run can be run simply by a webpage. I want to control my squeezebox radio. I can send a PLAY command via a html request. I just need elk to tell isy to do a get request on the url. If i add the network module, will that give me the ability to make a program in ISY to check the ELK status?
Killervette,
Currently, the only way of doing this is to assign one of your INSTEON/X10 devices as a variable:
1. In ELK, create rules that turn on/off that device in ISY
2. In ISY, create programs that based on the status of that device, a Network Resource is activated
Do you already have the Network Module?
So it has to be a real insteon device....i cant my a "virtual device"? I do not have the network module yet. I was waiting to see if i could make this work before buying.
  • 3 months later...
Hi killervette,
Unfortunately, at the moment, it has to be a real INSTEON device.
Has this been addressed in the 2.8.4 beta release? Do I still have to use a real insteon device?? It basically ties up a $45 device for my setup :(
      37.9k
      378.3k
