Does Insteon sell switches rated to dim LED drivers
Does Insteon offer any dimmer switches that can dim LED drivers instead of LED bulbs? We have some LED strip light that came with a driver, but I keep burning out the switch I have. Is there any solution for this with Insteon products?
Are the drivers rated as dimmable? If so, by traditional phase cut dimming methods? Some dimmable devices use a 0 to 10v signal instead. Insteon as planning on introducing such a voltage signal device.
Actually there was a 0-10V dimmer module. That was discontinued and now one is being brought back. No info on if it is the same one or a new design.
