Missing "UD mobile event template"
Added the Notification plugin and setup per "Notification for Dummies"  When I open the AC and look at the emails/notifications.customizations section, I do not see the "UD Mobile Event Template."  Any suggestions?
Did you create at least one notification with UD Mobile? According to the post by @Javi in the thread at least as of last year UD Mobile would create a template and increase the number if there was already one created. It's possible something has changed as both systems developed over the last year.
Might also need to run a sync on UD Mobile (while Admin Console was CLOSED) then re-launch admin console.
Thanks.  Will give it a try.
We have updated examples on creating and modifying notifications. These new examples show both the AC and UD Mobile at the same time.
Setup: https://youtu.be/KSmx-XIquAw
Sending to a specific Group or Device: https://youtu.be/z4pquLcI2Es
Creating your own notification content: https://youtu.be/KSmx-XIquAw?t=165
FYI: there is a bug in custom content prior to 5.9.1 which will not show customizations after a missing ID (sequentially).  This can be fixed by adding a new customization until all the gaps are filled.
