Process for refund from PG3 plugins store?
Go to solution Solved by Geddy,
It looks like a device controller isn't accepting connections from the new plugin I bought today because they're going out of business. So with the device dead and no replacements coming the plugin will never work. What's the process for getting a refund from the PG3 store?
Thx!
Thx!
I have an older RainMachine irrigation controller.  I don't use the plug-in, but the controller itself continues to work just fine.   I'm not sure about remote access as that required a subscription and I've never had one.
I don't know if the plug-in requires remote access or if it can communicate locally with the controller. But if it can communicate locally, that should continue to work regardless of the state of RainMachine's business.
I owned a rainmachine at my last house and the connection is local api. Before the current plugin was written, io_guy supported rainmachine through his nodelink node server and that was local.  &nbsp
The rainmachine is built on android and its webserver provides pages to configure the rainmachine locally. My recollection is the the full URLs and port numbers were specific.. I believe :8080
Yes, the Rain Machine app continues to work, at least on Android. With the exception of Notifications. I reported this to them at the end of last year and they responded that because of changes to Android they needed to rewrite the Notification portion of the app. They also indicated they were working on it.
However, so far there has not been an update and my inquiry last week has gone unresponded to.
While I never used the plugin for Rain Machine, remote access still works (without a subscription), but you need to open a port in your router.
Are you saying that the RainMachine controller has failed and isn't working at all?  In that case, you're right they'll probably never send you a replacement.  Your only option would be to look for a used controller (ebay?) or switch to something else.
Your post was a little ambiguous on that point, I wasn't sure if meant the controller had died or you couldn't get it working because they were out of business.
If the controller and it's app are still working and it's just the plug-in that's not, you might want to set the log level to debug and make a post in the RainMachine sub-forum for help.
  • Thanks 1
Thanks bpwwer. Yes, the controller coincidently died two days before I tried to migrate the Polisy PG2 Node Servers to eisy PG3 plugins. So, I replaced it with a Rachio, and support helped me swap out the RainMachine plug-in for one for Rachio. It's working great.
But bigger than that, I'm done with the overall project: old ISY99 + early separate blue box Polisy + lots of mixed Insteon and Z-Wave + 12 years of automation code + AWS and other external portal integrations + 6 Node Servers.. now all on one eisy. Maybe ten hours total planning, acquiring parts, and prep here and there over three of months, then the actual migration took less than an hour. Michel was awesome with helping resolve perquisite issues, and it worked as described the first time, including pulling all the Z-Wave nodes over.
      379.7k
