Unmanaged plugins after upgrade
Just migrated from Polisy to Eisy.  All went well, but Plugins dashboard shows all of my plugins are "unmanaged" and no response to "details" button.  I have deleted the old polisy on portal, cleared java cache, re-booted but no effect.
Solved by Geddy
@SHM did you follow the directions in the wiki to migrate the plugins?
Quote
  1. Backup PG3 on Polisy.
  2. Restore from PG3 backup on eisy using the "Migrate from PG3 Backup" option.
https://wiki.universal-devices.com/Eisy:User_Guide#Migrating_Node_Servers_to_PG3x
I'm not sure if this is still possible, but that's the last the wiki mentioned how to move them from Polisy to eisy.
When plugins show "unmanaged" in the dashboard it means they are being managed by another device. If you have everything that was installed on the Polisy showing on the eisy now make sure you start them (if possible). If not you might need to open a support ticket with UD to see how to get things sorted/moved.
Thank you.  I tried that but ended up re-installing and re-configuring each plugin
