ANDs and Parenthesis'
Go to solution Solved by Guy Lavoie,
I have three (3) ANDed conditions that must be met before an action, (THEN), can occur. what is best practice in IOX.
As I recall from past programming in IOX parenthesis' must be used for  ANDing or ORing at times. XOR and XAND. I always get this stuff mixed up these days!
So, is the following best, (pretty exclusive that the first two conditions must be met), practice...
             'Double Garage Door-Sensor' Status is On
         And $Can_Close is 1
    And $s_GarageDoorIsOPEN is 1
or is the code snippet the next best method to ensure that all 3 conditions are in fact met.
         And $Can_Close is 1
Thanks!!
John
Edited by johnjces
The second one seems to best reflect what you want to do, visually. Both are actually equivalent.
On 7/1/2025 at 6:41 PM, johnjces said:
Thank-you sir!
You don't need parenthesis at all for this.
There is no functional difference between either of the two options you showed as well as no parenthesis at all.
Mostly you would use parenthesis when you have two sets of conditions not connected by the same and/or.
ie.
(1 and 2 and 3) or (4 and 5)
(1 or 2 or 3) and (4 or 5)
the following are all  functionally identical
(1 and 2 and 3)
(1 and 2) and 3
1 and (2 and 3)
1 and 2 and 3
(1 and 3) and 2
  • Like 3
      38.2k
      381.1k
