unable to recover UD applet on desktop
I started by wanting to use the UD mobile app.  Once downloaded, I got an error message saying I needed to be on firmware 5.x.x.  I was still on a 4.x.x version.  So I downloaded the update.  I also updated java.  I followed the instructions in a different post and cleared java cache.  Now I cannot open start.jnlp.  any thoughts??
I have downloaded the start file several times.  start.jnlp shows in my downloads folder.  When I click on it, nothing happens
BTW, I have downloaded the latest java, running win 11, using microsoft edge browser
@Johns9149 when you say "nothing happens" does it not even ask you what to use to open the file?
Right click on start.jnlp and make sure that "Opens With" shows the "Java(TM) Web Launcher". That should be in the Java -> bin folder. Look for javaws.exe. (on my Win11 machine it's in C:\Program Files\Java\latest\jre-1.8\bin (also looks like it is in C:\Program Files\Java\jre1.8.0_461\bin)
If still nothing is happening make sure you're not running any 3rd party anti-virus (or firewall/vpn) software.
Lastly, when you're clearing java cache and have checked all 3 boxes you might have to manually force Java to remove any UD links. See below to find where to remove the application(s) listed. Also change the setting to deleted and remove any UD apps listed there.
Just to confirm based on what's on Java's site as of today - you're running:
Version 8 Update 461
Release date: July 15, 2025
Just the "plain" Java install when you visit java.com and click "Download Java for desktops" is all you should be running.
Geddy -- thanks for the suggestion of using the right click.  Yep, got me back in.  Now, any idea on how to the UD shortcut icon back????  I have moved the start.jnlp download icon to the desktop and I can get in that way.. just would be nice to get the shortcut back.  Again, thanks for your help
If it doesn’t add the shortcut when you run the start.jnlp you need to clear the java cache again (selecting all 3 boxes). Then run start.jnlp again. More than likely java thinks thins are installed and it’s not actively adding the shortcut. That’s typical following a Java update as well.
If none of the above works for you, try this:
Admin Console Minimized/Invisible and Cannot be Restored
This is usually related Admin Console state files not being updated properly and especially in case of multi monitors. All you need to do is to find the following files in Java temp directory (on Windows: c:\Users\[Username]\AppData\Local\Temp) and delete them. Or, you can simply search the computer for udi_*.state or ud_*.state file patterns:
ud_finder.state
udi_finder.state
udi_frame.state
udi_launcher.state
udi_pgm.state
udi_tree.state
Thank you to everyone who gave advice.  I finally got it all figured out.  I ended up uninstalling java then reinstalling it.  The UD shortcut immediately came back.  While I have had ISY since the 99 days, I have always seem to have a mental block when it comes to java.  I am comfortable adding / deleting devices, making scenes and programs.  But when it comes to java... well... just glad there is a community I can go to for help.
