Open and Close functions inverted
@sjenkins I've discovered that the "Open" and "Close" buttons in the nodes for the individual shades are inverted - "Open" closes the shades, and conversely "Close" opens them.
The "Activate" function in each of the Open and Close nodes works as expected though.
This is the same whether using the AC or UD Mobile, or in programs.
I don't know if this has been a long term or recent thing.  My HD system is a G3 running version 3.2.46 on the Gateway.
Iox 5.9.1, PG3x 3.3.21, HD 1.12.5 (exhibited same behaviour on .4, don't know about previous versions).
It's not a big issue as my programming uses the Open/Close nodes and functions correctly.
Thanks for the heads up. Haven’t changed anything recently & I mostly use Activate. Maybe I missed something in my test procedure. You are the first person to notice if so. I’ll check it out and get back to you.
@glarsen
so you are right!
I can say that I have open and close reversed for G3 ; open should be 100, close 0 position.
TODO: can someone who has G2 can check if Open / Close works as expected?  When I developed it, the G2-API has open as 0 and close as 100 ; the opposite of G3.  I only have G3 blinds.
Not sure how I messed this up or how you are the first to notice as these lines were committed in Jan-2024 !
@glarsen you win the observant user award !  The rest of us should hang our heads :)
