brianh32877 Posted yesterday at 12:58 AM Posted yesterday at 12:58 AM I've got an iTach IP2IR that turns on digital poster frames in my theater. It ran with my old ISY994 without any problems for years. I finally switched over to Eisy, connected a Flirc to use the IR node server and got the commands from my Harmony remote working with Eisy. But now the iTach doesn't want to work. I've downloaded the newest release software from the iTach website, updated the firmware and deleted/reinstalled the PG3 iTach node server and rebooted everything. When I try to test the commands I've learned, I get the errors seen in the attached screenshots. Can anyone help me out? Thanks Quote
Javi Posted yesterday at 03:31 PM Posted yesterday at 03:31 PM Have you tried the iTach Node Server? See pinned topin in subforum below. https://forum.universal-devices.com/forum/324-itach-ir/ For Network Resource check port and termination "\r\n" at the end of the command Quote
apostolakisl Posted 23 hours ago Posted 23 hours ago (edited) Are you using the itach node server or network resources? You say you are using the node server but you are showing network resource screen shot. The flirc and the itach are fully separate so having or not having a flirc is not going to affect the itach. This is an example of one of my "body" sections for a network resource. sendir,1:1,1,38343,1,1,16,179,12,183,12,183,13,182,14,181,16,275,19,176,19,272,19,176,19,176,19,176,19,3834\r\n\n And this is what my itach node server setup looks like for one device. I had an itach prior to the node server existing so I have some things still on the network resources but have been trying to moving everything over to the node server because it is nicer to work with once configured. "whole house on","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,274,19,178,19,178,19,178,19,274,19,3858" "whole house off","sendir,1:1,1,38343,1,1,15,180,14,181,19,176,19,176,19,176,19,272,19,272,19,176,19,176,19,177,19,272,19,4907" "system off","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,274,19,274,19,274,19,178,19,178,19,178,19,3858" "Zone on/off","sendir,1:1,1,38226,1,1,10,185,10,184,14,181,19,176,19,176,19,176,19,176,19,176,19,176,19,176,19,176,19,3822" "Volume Up","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,178,19,274,19,178,19,178,19,3858" "Volume Down","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,274,19,178,19,178,19,274,19,178,19,178,19,3858" "Mute","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,178,19,178,19,274,19,178,19,3858" "Do Not Disturb","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,178,19,178,19,274,19,274,19,3858" "Source 6","sendir,1:1,1,38343,1,1,16,179,12,183,12,183,13,182,14,181,16,275,19,176,19,272,19,176,19,176,19,176,19,3834" "Source 5","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,274,19,274,19,178,19,178,19,3858" "Source 4","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,274,19,178,19,274,19,274,19,3858" "Source 3","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,274,19,178,19,274,19,178,19,3858" "Source 2","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,274,19,178,19,178,19,274,19,3858" "Source 1","sendir,1:1,1,38580,1,1,19,177,19,177,19,177,19,178,19,178,19,178,19,178,19,274,19,178,19,178,19,178,19,3858" Also: I noticed your are sending network resources on port 4997. Mine is setup on port 4998. ***Pretty sure your port number needs to be changed to 4998. All the docs that came up on a google said it works on port 4998. Edited 23 hours ago by apostolakisl Quote
