programs run when modified and saved
I've noticed that some programs run when I click "save changes" after I modify them, even though they shouldn't run. In this example:
       Time is  1:35:00PM
    Or Time is  7:45:00PM
       Set 'I / Hearth-9-Audio System IOLinc' 1 (Beep Duration)
       Set Scene 'Audio System' Off
       Disable Program 'audio on when Return **'
I make a change to the program, then I click "save changes" and then it runs, even though it isn't 1:35pm or 7:45 pm.
This isn't normally a problem, but the other day, I was modifying programs while the wife was asleep and it turned on the lights in our bedroom. not good. The combination of this and the PLM problems I've had lately and the WAF has gone right down the crapper.
Here is what my grace period is:
I tested it and it works. I must have been within the thirty minutes.
