After update, Pg3 cannot find IOX
I knew better....
I did the Upgrade Packages in Eisy.
Now when I go to PG3, I get "Not connected to server... Try refreshing the page. This will disappear once the connection is re-established"
I have searched for the IOX
I reset rebooted multiple times.
I pulled the power and restarted
I tried to re-enter a new IOX with HTTP and HTTPS with no luck.
I searched the forum, however the search function is not working the way I expect it to.
What am I missing?
Thank you in advance!
For future reference-
UDI support helped me solve the issue.
Microsoft Edge was my default browser even though I hardly ever use it. When I clicked to open PG3 from the Java interface, it used Edge. I cleared the Java and Edge cache but it never would work.
The resolution was to open PG3 in another browser and it worked fine.
PG3 was running the whole time, I just couldn't access it.
@rg65
PG3 works fine with the edge browser, I've been using it from day one. You may have had a setting in the browser that was blocking PG3
15 minutes ago, Techman said:
@rg65
It has been working for some time with PG3, but something stopped after the update.
