ISY skill will soon no longer work at all on Alexa+
I have upgraded to the new Alexa+ service (AI version of Alexa), and its now telling me the existing skill (ISY Optimized for Smart Home V3) will no longer be supported in a week. Every time I give Alexa a command for an ISY device, it executes it, but then says:
"The skill for <device name> hasn't upgraded to support the latest version of Alexa. You will no longer be able to use this device with Alexa starting November 4th"
How can we get an upgraded skill that is supported by Alexa+? I don't want to lose all my device control via Alexa. The only alternative is to unregister for Alexa+ and go back to the original Alexa experience.
Apparently they have new SDKs for developing new AI compatible skills.
https://developer.amazon.com/en-US/blogs/alexa/alexa-skills-kit/2025/02/new-alexa-announce-blog
Edited by BILJ
Add a few clarifications and additional info about the new SDKs available.
Solved by bmercier
What is being removed on November 1st is support for the Amazon Smart Home API V2. This used to be the case for our older "ISY Optimized for Smart Home V2" skill.
The "ISY Optimized for Smart Home V3" skill uses the Amazon Smart Home API V3. This is still supported and the only current way to implement a Smart Home skill for Alexa.
When using Alexa+, this still works with smart home skills. The new "AI-native SDK for Alexa+" allows to develop custom skills. I guess it could be used to control devices, just like the older Alexa custom skill API could do. But regardless, smart home skills using the V3 API is still the current way to develop smart home skills.
Now, I have had many reports of users receiving the warning you mention. I do not know for sure why. I believe this may happen if you used to have the older ISY Optimized for Smart Home V2. Either it's still there (along with the V3 skill), or there's some remnants of the older devices existing in the account.
In preparation, make sure the skill you are using is "ISY Optimized for Smart Home V3".
On November 1st, if you see some devices are no longer responding, please do this:
  • Login to the Alexa app, test the device there.
  • If you see it is not working, delete it from the Alexa app.
  • Ask "Alexa, discover my devices".
    • This should recreate the device in your Alexa app based on the configuration you have on my.isy.io.
    • If it doesn't, login to my.isy.io, look under Select tool | Connectivity | Alexa.
    • Make sure that your device is there. If it is not, create it. It may be that device was created a long time ago using the V2 skill. With the V3 skill, the device discovery will create a V3 device in your Alexa account.
when I added the V3 skill, I looked for the V2 skill to remove it and it was nowhere to be found. Perhaps there is a way to find it and remove it?
and by the way; its actually "after November 4".
Yes, I also had the V2 skill earlier and when I switched to V3 I always felt the V2 skill was still running but it was not listed in the app, and there seems to be no way to delete a skill. Having both active could explain other strange behaviors. I guess I will see what happens after Nov 4, hopefully it will continue working via the V3 skill, and I do appreciate the great writeup from bmercier with the tips.
I have the ISY Optimized for Smart Home V2. How do I upgrade it to V3?
You can follow the information in the wiki:
https://wiki.universal-devices.com/ISY_Portal_Amazon_Echo_Integration_V3
You'll want to disable/unlink the V2 skill first. Not a requirement, but might actually remove it from the Echo/Alexa "my skills" and not give you a warning about it not working soon.
@bmercier
I just went through this at my daughters house. she was getting the no longer supported message when issueing commands. She was on V3 of the skill.
It turned out ONE of her 5 echo's had the Alexa + skill , 4 did not but all responded with the message. removing it from the ONE made the message stop.
In adddition, when the ONE was enabled, the Alexa App did not show skills, just alexa programs. Once removed, the App showed skills again.
So... any alexa device on your account makes the skill anoying at best, useless at worst.
I believe the newest Alexa devices only support Alexa +.
does this mean ISY will not support the newer Devices, or will you look into supporting Alexa + ??
My wife is threatening divorce if I don't get Alexa to stop talking back to her when she's trying to simply turn off the lights.
I removed the skill completely, deleted all devices from Alexa... And the re-enabled the v3 skill, and re-discovered all devices and scenes.
Alexa still insists that the skill will stop working starting November 4th.
At this rate - the marriage may survive Christmas... But 2026 may a be rough New Year if I have to choose between Alexa or my wife.
Edited by MNicholes
@bmercier that is correct. If any one or all are on Alexa + . As I said above, if you enable Alexa + on any unit, the alexa app no longer has a click box to show installed skills, It is replaced with "Alexa Programs"
@bmercier @MNicholes additional info - I had to go to each Alexa unit at daughters house and tell it to revert to old Alexa. Most of the units replyed with It couldnt perform the operation since they wer not the units that had Alexa + enabled. When I finall found the one that had it enabled it reverted. This my origional question. If you purchase a new unit that has Alexa + installed, you introduce the issue and I do not know it the newer units allow you to revert
I'd like to keep the alexa + capability but get rid of the sassy "... November 4..." responses. any suggestions?
bgrubb1, how do you tell if you have Alexa+, and if so how do you remove it to get back to ordinary Alexa?
you can go into the alexa app and see if you have a button for skills. If you dont you have alexa +
go to each alexa device and say "Alexa, end early access"
I have been living with this warning as well (Alexa+ enabled), same thing about the wife wanting to kill me. As of today, Alexa is reporting that the skill is disabled and will not control any devices. I have the ISY Optimized for Smart Home V3 skill installed and it does not say it's disabled.
I am running an EISY with older software on my EISY, I have not had time to upgrade yet, not sure if this is related.
FreeBSD eisy 13.1-RELEASE-p7 FreeBSD 13.1-RELEASE-p7 #9 releng/13.1-n250182-00935d2e533c-dirty: Tue Feb 28 19:35:27 UTC 2023
Any assistance appreciated as we use the Alexa skill all the time.
FYI:
I went into the isy.io access for alexa and found that my "devices" still worked as listed in the "amazon echo device list" but the "scenes" did not work.
I then went into the alexa app and asked it (by typing "disable alexa+") and it did so and then, voilà: all of my scenes and devices all work without any problems! I'll just await this being solved and then re-enable alexa+.
Ok, so on Nov 13th they finally shut down the V2 skill and the message is now “I can’t control the <device name> because its skill is disabled. You can find the skill and enable it again in the Alexa app.”
I’ve done a lot of experimentation, and cleared all my Echo spokens in the portal, disabled/reenabled/relinked the ISY V3 skill (no V2 skill appears, although I did originally use the V2 skill yesrs ago). I’ve reset and reconfigured several times and come to this theory based on the behaviors.
  • the original “spokens” I set up long ago on V2 skill are still in Amazon’s brain, and are still tied to the V2 skill which must still be active somehow, (though disabled now under Alexa+)
  • If I disable the V3 skill, I can see that all ISY devices are GONE in the Alexa app. Issuing a command to one of the old spokens still returns that message about the skill being disabled. This tells me the V2 skill is still somehow defined and its spokens are forever tied to it. But if I try to command a more recent device that was newly defined under V3, its unknown to Alexa because all the V3 spokens got deleted when I disabled it.
  • If I re-enable the V3 skill with all ISY portal device spokens deleted, I initially have no ISY devices shown in Alexa.
  • If I redefine a device and spoken in the portal, I immediately see a notification from the Alexa app that the device (the spoken) has been added to the V3 skill. It explicity mentions the V3 skill by name.
  • If the device I re-added is using the same spoken as from years ago, I get that error message again and the command fails. I strongly suspect that the spoken exists twice in Alexa’s brain, once for V2 skill, and once for V3 skill, and the V2 skill always takes precedence. This theory fits with earlier behaviors over the years where sometimes I’d get dialogs like: ME: Alexa, turn on Apple TV; ALEXA: there is more than once device with that name. Did you mean “Apple TV” or “Apple TV”? ME: “Apple TV” ALEXA: “Ok”
  • On spokens that persistently won’t work anymore, if I simply change or add another spoken to the device in the portal, it magically works in Alexa, but only with the new spoken. So now I am stuck having to say “Alexa, turn on New Apple TV” and it works.
I’m not crazy about having to use modified spokens, but I see no true solution as there’s no way I’ve found to purge the old spokens once and for all. At least I have access again to these devices with new spoken.
I've found a way to get rid of the duplicate items. it has been mentioned before.
1) create a group with the name, e.g. "kitchen lights"
2) upon creating the group you add in both the "devices" called kitchen lights and the "scene" that is called kitchen lights. Interestingly, when you look through the list to find the kitchen lights, there are dozens more devices that are available when using them normally.
3) once the group has been created, it should work just fine. somehow, as has been noted previously in this thread, groups take precedence over devices and scenes.
this will solve the duplicate devices problem. but: I went a little further and found that if you mess around with the group, you can figure out which device and which scenes actually work and which are the broken ones (perhaps they are the ones connected to the V2 skill). you can then, while still modifying the group, deleted those devices or scenes...... BUT THE PROBLEM I had with doing this is the the V3 skill did not work consistently when using alexa+. (here is what I mean: if I said "turn the kitchen lights on" 10 times, it would work maybe 4 times and not work the other 6. I couldn't figure out any reason why it only worked part of the time.)
Here is how I solved the “I can’t control the <device name> because its skill is disabled. You can find the skill and enable it again in the Alexa app" problem: I downgraded to remove alexa+ for now. I liked alexa+ but the problems with the voice controls weren't worth it.
I also removed Alexa+, but would love to re-enable it if a solution is found.
FYI, I found a way to access the Skills list even with Alexa+. In the app, in the "Ask Alexa" search field at the bottom, type "Skills" and send. It will reply back with a link you can click to access the old skills screen, and at the bottom you can click "Your skills" to see what you have. This is how I was disabling/reenabling the ISY V3 skill under Alexa+.
I still think my troubles are from having spokens that were first created under V2, and even though I recreate them fresh in V3, they still try to trigger the now defunct V2 skill. If I simply add an additional, never before used spoken the existing one, that new spoken works fine, but original spoken triggers the V2 and gives error. Additionally, on more recent devices where spokens were only created under V3 skill, they still work fine in Alexa+ without any error response, since they never existed under V2.
Is anyone addressing this? I assume at some point new amazon devices will not support vanilla Alexa. Is this a plug-in issue or an Amazon issue? I'd really live to move on to Alexa+, but I can't afford to break the means I use 90% of the time to manage our lights.
Same issue here. All my scenes stopped working when I upgraded to Alexa+ - fortunately for Grok, I saw I was able to revert to old Alexa, and everything works again. Is there an ETA for the upgrade to the UD Skill to work with Alexa +?
