December 15Dec 15 9 hours ago, apostolakisl said:There is an update to udx (v4.2.0) that corrects the Elk Plugin from displaying names instead of numerical values in UD Mobile & eisy-ui. It is available from the upgrade packages in the admin console.Run: https://eisy.local:8443/WEB/sysconfig.txt to check your version of udx. If it is at least v4.2.0, then reboot eisy. After complete startup, synchronize UD Mobile and you should be good to go.
December 15Dec 15 Author 6 minutes ago, DennisC said:There is an update to udx (v4.2.0) that corrects the Elk Plugin from displaying names instead of numerical values in UD Mobile & eisy-ui. It is available from the upgrade packages in the admin console.Run: https://eisy.local:8443/WEB/sysconfig.txt to check your version of udx. If it is at least v4.2.0, then reboot eisy. After complete startup, synchronize UD Mobile and you should be good to go.I already have the latest updates.
December 15Dec 15 I have 4.2.0 and have synced. I still get GVxDo I still need to reboot if I have 4.2.0? Need to upgrade packages?Thanks,John
December 15Dec 15 I would suggest upgrading packages to be sure all went well with the upgrade, and rebooting. After everything is up and running (be sure to check all plugins have started - there is a separate issue with plugins not restarting after reboot), then synchronize UD Mobile.If that doesn't work, I would then open a new support ticket, as something else is going on.
December 15Dec 15 Author 20 hours ago, JSchumann said:I have 4.2.0 and have synced. I still get GVxDo I still need to reboot if I have 4.2.0? Need to upgrade packages?Thanks,JohnI am on 4.2.0 as well. It fixed the similar issue with Elk node not populating, but either created or didn't fix the GVx issue with programs. I don't often look at programs on UD mobile, so not sure when it started.@Javi Edited December 15Dec 15 by apostolakisl
December 17Dec 17 Solution Please try synchronization, The most recent app update should have alerted all users on first open to synchronize....should also be much faster
