22 hours ago22 hr Author On 6/4/2026 at 7:58 PM, Techman said:The "Not Specified" refers to a device that has been removed and/or failed.. You need to specify a device.There's no way to extract a single device from a backup.Thank you sir.Now I think I already know the answer to this question, but might as well ask, as I always learn new stuff here.Is there any utility/trick to scan a ISY Backup file and get the same style Programs text file as we do from the process @Geddy describes above? When I drill down through the contents of the ISY zip file, I get another zip file like UUID......zip, and then get a CONF folder, below that are a bunch of files and folders.
3 hours ago3 hr The only way is to copy your program folder to the clipboard, "Copy to Clipboard" and then paste in your Notepad or Word. You would then have a searchable text file to work with. This only works with the current program file.You can all create a toploogy report, File, Create Topology, which will give you info on your devices and scenes
