March 3Mar 3 No big deal but annoying. Open UD mobile and two thermostats show in favorites with only one populated with current stats and the other blank..The only way to show current stats is to switch to dashboard then switch back..It then will show all the correct values on the favorites view. Have to do this every time UD Mobile is opened….Any ideas? Edited March 4Mar 4 by drprm1
March 15Mar 15 On 3/13/2026 at 9:19 AM, Javi said:Issue should be resolved in yesterday's firmware release.I have a similar issue with an Elk node. I have two garages that are monitored by Elk alarm. I set them both up to display on my favorites page. But only one of them ever populates without doing a query. The other always populates. They are identical to each other except for the specific Elk sub-node referenced. It has been like this for a very long time. If I close UD mobile and open it back up, the node is again not populated. According to google play store, I am up to date on ud mobile app. If I look at all of my Elk nodes, it seems hit or miss which ones are populated. What can I do about this?
March 16Mar 16 22 hours ago, apostolakisl said:I have a similar issue with an Elk node. I have two garages that are monitored by Elk alarm. I set them both up to display on my favorites page. But only one of them ever populates without doing a query. The other always populates. They are identical to each other except for the specific Elk sub-node referenced. It has been like this for a very long time. If I close UD mobile and open it back up, the node is again not populated. According to google play store, I am up to date on ud mobile app. If I look at all of my Elk nodes, it seems hit or miss which ones are populated. What can I do about this?Did eisy firmware 6.0.5 correct the issue?
March 18Mar 18 On 3/16/2026 at 7:41 AM, Javi said:Did eisy firmware 6.0.5 correct the issue?Initial testing would indicate yes. The one node populates several seconds before the other, but it does populate and previously it never populated without a query.
