migrattion and only half of the devices work
I dont a migration from my isy994. I been having so many problem from the system stying bust to trying to link its for hours. Now That that has stooped on have of the device insteon devices woek. I have rewote to the try retstore them and yet nothing. I going to pull my hair out been on this for days now.
Migrating from a ISY994i to a eisy? Is it just Insteon devices or also Zwave? Did you keep the same PLM, using a serial to USB adapter?
only Insteon and samae plm usb, And yes I did restore devices several times.
Edited by danncas
add on
I'm guessing that "That that has stooped on have of the device insteon devices woek" means half of the devices work? If so, are the non working ones battery powered devices, like leak detectors or open close sensors? If that's the case, you might need to relink those manually.
finally got it migrated with out error BUT NOW IT SAWE PLM NOT CONNECTED. BUT IT IS?????
Try powering off your eisy for a few minutes, then turn it back on. Then log back in and see if the PLM now shows as responding ok.
