March 10Mar 10 Hi - new to the forum so excuse the novice question.I think I might have purchased twice - see screenshot? I'm not understanding why so many entires.I followed the setup steps but seeing this in my dashboard and still not getting anything to configure alerts in the java admin console. I entered portal key, app key, etc. Any ideas?Thanks for the help.
March 10Mar 10 @JLevy02 it might be best to address this directly with UD through their support ticket. They can check if you inadvertently purchased twice and work out a refund if you did.https://www.universal-devices.com/my-ticketsIf you click on the "Details" button of the plugin you should then have a configuration option. Since both the Elk and Notification show to have nodes currently something has been setup.
March 10Mar 10 Author UD said 4 entries on the "purchased" apps was standard and fine.... OK.I still don't see anything in the actual java admin console despite follow-ing all the setup steps. Any tips on what to look for?
March 10Mar 10 If you are referring to the number after the plugin name, i.e. ELK(2), that's the slot that the plugin is installed in.
March 10Mar 10 Author sorry I'm not being clear, I have notifications installed on slot 3. When I click details there are 4 "nodes" ( I don't know why).I've attached a screen shot of the nodes.On the config page, I've set the 'acknowledge', rest_port, and portal_api_key.I've also set the pushover service nodes based on keys from pushover.I've also set ISY service notes using same portal_api_key as above.I've rebooted everything a few times. Shouldn't a see a GUI in the client admin console to configure notifications? I don't. Polyglot V3.pdf
March 11Mar 11 @JLevy02 In Admin console click the Configuration tab then Email/Notifications tab then Customization tab. Set up Notifications there.. in the plugin store click on the Notification plugin then you will see a more info tab that has a lot of information on how the set up the notifications. Edited March 11Mar 11 by tlightne
March 11Mar 11 Author I had those settings all the time, before I ever bought this option. I thought this was supposed to add a node about the notification controller to the admin console that let's me do more advanced notifications, direct to pushover, more variable options, etc.
March 11Mar 11 Solution Sounds like you need to follow the examples for setup and using the Notification plugin. Take a look at these:JimBo Automates - PG3 Node Serversairscape
March 11Mar 11 Author that guide helped! Somehow I had the rest port set to 8199 but didn't need that. changed to 0 and the node showed up! Thanks
